Polishing TS-17
I never seem to be able to get this paint to work right. Is it just me or is it difficult to work with?
I decanted and airbrushed TS-17 and the body has some small bumps. Not like orange peel, but a little more textured. I've also got a few pieces of fuzz on the paint. Can TS-17 be wetsanded or will this throw off the color/flakes of the adjoining areas. How do you deal with surface imperfections and this paint? Thanks in advance. |
Re: Polishing TS-17
The paint will change badly if sanded. I recommend a nice coat of clear and then polishing. Make sure you start out lightly with the clear. Too wet too soon and you can make the silver run and mess it up.
Mark |
Image Hosting Exceeded
![]() Join Date: May 2003
Re: Polishing TS-17
The last layer of paint before clearcoating must be perfect (or as close to perfect as you can practically manage). No texture, no debris, no flaws, nothing. If you are not happy with it, definitely do not move on to clearcoating.
Once you have built up an opaque layer of color, any texture or debris gets gently sanded out, and then lightly overcoated with more paint. Use the finest abrasive possible, and do it dry (no wet sanding!). Then overcoat with very fine mistcoats until evidence of the sanding is invisible. If flaws are still visible, do it again. And again. It is not difficult to get the last layer right- but it does take patience, and often several iterations. And very light mistcoats of paint. But you should be doing that anyway.
PHOTOBUCKET SUCKS |
Re: Polishing TS-17
I've had problems with TS-17 during the color coat stage. Even though I was doing everything right, or so I thought, I always get clouding.
Re: Polishing TS-17
Have any of you tried the new Tamiya TS 83 Metallic Silver and TS 84 Metallic Gold yet?? I found them at my LHS for $16.99!!!
Re: Polishing TS-17
I wish I read this before I started.... I wetsanded the imperfections out planning on doing another coat when I noticed that the paint was starting to pull away in little chunks in areas. We'll see how it ends up.
![]() Do you guys use any kind of filter or line dryer on your compressor? I'm using my compressor that I use for my pneumatic nailer; is it giving me dirty air? This is on sale for $49.99. Would it be better? I just picked up their deluxe airbrush for $14.99; pretty nice AB and it's a double action! |
#7 | ||
Re: Polishing TS-17
#8 | ||
Re: Polishing TS-17
Mark |
#9 | ||
Re: Polishing TS-17
The cans actually stated that a black gloss coat is required before laying down the paints (might actually go and get them now )Sorry for the OT, jmwallac! But I also never be able to lay down a smooth paint with TS-17. |
#10 | |
Re: Polishing TS-17
For me, dealing with stuff like fuzz or other debris, I lightly sand it out using as high a grade as I can, then touch it back up with light mist coats...trying to blend the area back in (some metallic particle paints will require more attention to the angle you spray at). Finally, clear over it. Airbrushing paint shouldn't give "bumps" unless there is a contaminent (maybe water in your air?) I would think. The paint should be atomized before touching the body surface.
On a side note, I'm curious why MPWR suggests not to wet sand it. I always thought the water would help remove the fine dust .
#11 | ||
Re: Polishing TS-17
PHOTOBUCKET SUCKS |
#12 | |
Re: Polishing TS-17
Thank you for that explanation. The dust from wet sanding is, as you have said, trickier to deal with. That's probably why my polishing pads are slightly getting clogged up now
. Thanks again.
