Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 12-18-2008, 08:32 PM   #1
CrazyHorst
SES light flashing while driving
Anyone else ever experience this?
I hadn't seen that one before.
The condition at the time of the flashing SES is a low-rpm, high load "sag" which feels from the seat of my pants like a misfire condition on one cylinder.
I believe it to have to do with plug wires needing replacement and either "cross-talking" or leaking to ground, as this just started with the rain-every-day weather we started having recently. It mitigates as the car warms up which would hint at heat driving off the moisture.
Present unresolved codes are P0128 - coolant temp sensor and P0141 - post cat O2 sensor unhappy, however the vehicle ran perfectly for several thousand miles with these stored.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
CrazyHorst is offline   Reply With Quote
Old 12-18-2008, 08:39 PM   #2
tblake
In God We Trust
tblake's Avatar
Re: SES light flashing while driving
I think your on the right track. Scan it out to get the specific cylinder thats missfiring. Or else do a cylinder drop test. Once you found the defective cylinder, you may want to pull the plug and see what it looks like. If wet, chances are the fuel system isnt the problem. You could also do a quick compression check just to rule out mechanical issues. From there you'll probably be all set to replace the plugs and wires.
-2000 Grand Prix GTP 170,000mi (daily driver)
-2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal)
-1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix])
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
"I'll Keep my Guns, Freedom, and Money. You can Keep the Change!"
----->>>>> Did You Know? <<<<<-----
tblake is offline   Reply With Quote
