Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 12-08-2008, 10:40 AM
pSquared pSquared is offline
6VD1 advice needed for low compression (expert pls)
Hopefully a 6VD1 3.2 DOHC guru out there can spare some advice.
'92 Trooper w/just at 100K on well maintained, babied motor. Yet, told wouldn't pass CA emissions due to burned valve(s) #2 cyl, causing low to no compression. Which I went home and confirmed.
I find that a bit unusual that a car w/only 100k miles these days would burn
valve(s), but I guess it's possible.
My question, how to approach a fix. I know it's a fairly complex engine, but got no choice or $$, so gotta do it myself. Confident I can, done worse. But
wondering which way to go.
Pull the head & find a replacement? Valve job? Better yet, what could cause this? Lifter fail?
Just looking for some clue or direction.
Thanks in advance.
p2
Old 12-10-2008, 12:53 AM
Ramblin Fever Ramblin Fever is offline
Re: 6VD1 advice needed for low compression (expert pls)
First things first, how old is your timing belt? Has it ever been changed out?
A timing belt that's stretched can cause timing issues, which could possibly be related??
What kind of oil have you used in the past?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 12-10-2008, 10:39 AM
Timing belts & tensioner replaced around 90k. Oil's changed religiously every 3,500 mi. Kendall GT1 10w 30 or 40 in Summer.
p2
