Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 03-22-2005, 01:06 PM
MSAUTO MSAUTO is offline
2000 Corvett Ac Blows Cold On One Side Hot On The Other
Replaced Control Unit No Change The Ac Blows Vent Air On Drivers Side And Hot Or Cold On Passenger Side
Old 03-26-2005, 04:49 AM
icethepuck icethepuck is offline
Re: 2000 Corvett Ac Blows Cold On One Side Hot On The Other
If you don't mind me asking, how much did the control unit cost? Did you do it yourself, and if so was it hard to change?
Old 09-03-2006, 06:23 PM
crzy 4 vettes crzy 4 vettes is offline
Let me know if find out what the problem is because I am having the same thing happen to mine. Hot on the drivers side and cold on the passenger side. If I find out first I will let you know.
Old 09-04-2006, 11:58 PM
TEXAS-HOTROD TEXAS-HOTROD is offline
You'll have to get deeper into the system. The air flaps should be operated by electric servos. You need to locate that servo, operate the temp.control knob and look for movement at the servo.
The system uses air temp sensors to determine vent temp. You should have the body control system scanned and determine what the BCM is actually seeing. A misread vent temp would cause hot/cold problems.
Old 09-05-2006, 03:01 PM
imabballer imabballer is offline
i'm not familiar with the 2000 model, does it have dual zone climate control i presume?
Old 10-14-2006, 10:55 PM
16th hippy 16th hippy is offline
is most likely the temp actuator door for the respective side having the temp problem(since there are 2 of you with same problem but sifferent sides of car).
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 12-07-2008, 10:19 AM
albrum40 albrum40 is offline
if you don't care let me know what your problem was. I have a 99 doing just the opposite, thanks
