Old 07-07-2008, 03:23 PM
flash12 flash12 is offline
Whats the best way to change fuel pump on my 98 crew cab 3500 Dually?
Guys, whats the best way to change the fuel pump on my 98 crew cab 3500 dually? Drop the tank or pull the bed off? Also do you guys have any tips or tricks that will help speed up the process for me?
Thanks!
Old 07-07-2008, 07:17 PM
777stickman 777stickman is offline
Re: Whats the best way to change fuel pump on my 98 crew cab 3500 Dually?
The only tip I have is to get an AC-Delco pump that's matched to your VIN.
Over the years I've been here, there's been lots of posts about changing the pump in a pickup. Seems the bed removal takes precedence over the tank drop. So it's kinda up to you.
Make sure you brush and vacuum the area around the pump before you take it out. Lube the o-ring on the new pump and in the o-ring tank area. Check the electrical connectors and the ground area at the pump for good contacts.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 07-07-2008, 09:18 PM
2500HD4x4's Avatar
2500HD4x4 2500HD4x4 is offline
I've dropped the tank once and pulled beds off 4 times now (my truck and others). The bed is much easier, even though you have a dually, I would pull the bed off.
8 bolts from the frame to the bed, fuel filler neck & ground strap, rear light wiring harnesses and ground strap, and that's it I think. After doing this several times, I could pull the bed off within 30 minutes. As the previous post mentioned, take your time with the fuel pump itself, clean around everything before pulling the old one out, check the ground connection, and when re-installing the new pump, make sure to be careful with the float. When installing, seems to work best for me when dropping the float all the way (at a 90 degree angle to the rest of the assembly), fishing that through the hole in the tank, and then dropping the rest of the unit in. Also, make sure the new o-ring gets seated well. I had one occurence when it became pinched and fuel leaked out the top of the tank when filling up.
As far as hoisting the bed off after everything is unbolted (I have an 8' bed), I've done it with straps and an overhead hoist (very easy), picked it off with 2 guys (very hard), 3 guys (moderate strain), and 4 guys (quite easy). Remove your tailgate and use a lift, or 4 guys for the dually. Good luck.
1998 Silverado 2500HD
5.7L - 4x4 w/ Eaton Locking Diff
348,000 MILES
1993 Silverado 2500
449,000 MILES
Old 07-17-2008, 09:50 AM
I ended up taking everyone's advice and went with the AC Delco pump. I got lucky and found a brand new one in the box on Ebay. An AC DELCO MU145 with the GFT stamped on the top to match my truck. It was $79.99 plus shipping. Cost me $103 shipped in. The dealer wanted over $400 for it
Old 07-20-2008, 09:40 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
how many people you need to remove truck bed? say, strong guys?
Old 07-21-2008, 09:32 AM
We had five guys when we pulled the bed off my longbed dually. I think you could get by with 3-4 on a shortbed without duals.
Old 07-23-2008, 08:26 AM
CrazyHorst CrazyHorst is offline
Strangely enough, if you have a forklift handy...I've found this is an awesome tool for dropping a tank.
You don't need the heavy lifting power but just the steady forks to hold the tank with whatever amount of fill is in there. Use wooden blocking (2x4s, 4x4s, etc) if bodywork gets in the way. Your hands are free to remove the strap bolts, undo fuel line and electrical connections, etc.
Then 'inch' the tank back up when done to reconnect the straps.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 09-24-2008, 07:36 PM
ChevyBobby's Avatar
ChevyBobby ChevyBobby is offline
Does anyone know what the GFT code means? Like psi or maybe pin oouts?
Mine ins GFT also.
I personally and cutting a door to get to the pump. I have a Utility Topper and I don't feel like dropping the tank. So I am making a reinforced door to access it.
Just a thought
"Most people, sometime in their lives, stumble across the truth. Most jump up, brush themselves off, and hurry on about their business as if nothing happened."
Old 09-29-2008, 09:56 AM
acewelderman's Avatar
acewelderman acewelderman is offline
Dont forget ,you will need the special line disconect tool for GM vehicles.
Good luck!
JUST WELD IT !!
