Old 09-13-2008, 12:38 PM
damdash damdash is offline
a/c compressor not switching on
My dad has a 93 chevy cheyenne with a 4.3 v6. A couple weeks ago i added some freon to the system and everything was fine. After running the system for two or three days it stopped working. I thought it may have been a leak so i tried to add freon and it wouldn't take. After looking over it i see the compressor is not kicking on. when i jump it, it comes right on. I can't find any relays or disconnected wires. What else should i be looking for to fix this?
Old 09-17-2008, 09:54 AM
bigcoconut bigcoconut is offline
Re: a/c compressor not switching on
Too much pressure in the system will lock out the compressor. There is a pressure switch on the dryer (up near or on the firewall) that won't allow the compressor to kick on if too high or too low. IF you jump the compressor, bypass the switch, it will turn on. If your freon pressure is good, then the switch may be bad.
"Yes I have a truck and No I won't help you move your stuff..."
2008 Kawasaki KLR650 2500mi (fairweather commuter)
1992 C1500 Silverado 235,000mi (daily, not so much anymore, driver)
1999 Venture 120,000mi (moms vacation bus)
1989 Dodge Ramcharger SOLD, Yee-Freak'in-Haw
Old 09-18-2008, 02:53 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
There are two pressure switches, one for too low, and one for too high. A manifold gauge set is the best way to determine if the system is overcharged. The dinky quick gauges sold with refrigerant cans don't show this high-side pressure.
Was your system converted to R-134 or did it come from the factory that way?
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
