Old 09-04-2008, 02:39 PM
PMS PMS is offline
95 Lumina bucks at 50mph after driv 10 min
95 Lumina bucks at 45 - 55 mph after car is warmed up and driven for about 10 minuntes. What should I do first to fix the problem. Thank you for any help.
Old 09-04-2008, 02:50 PM
inafogg inafogg is offline
Re: 95 Lumina bucks at 50mph after driv 10 min
like most when you discribe buck/miss you need to check the basics.when was last tune up??how many miles??? like most you dont mention miles/engine & what has or has'nt been done.it maybe a plug/wire that is breaking down when there is a load on engine.check the basics & let us no
is the ''engine lamp'' on???
Old 09-04-2008, 03:33 PM
travelair travelair is offline
The torque converter clutch (TCC) is known to produce such symptoms. Not good news if it is because it requires removal of the tranny to get to it. Also, I've been told that a bad TCC is indicative of other major problems and it's better to just replace the transmission altogether.
If you have a "check engine" light on, there is (surprisingly) a code for this. My '95 is having TC problems as well, I think, but I have no light.
Check the basics first of course.
Old 09-04-2008, 04:14 PM
maxwedge maxwedge is offline
A990 racer
A scan using a trans function scanner will reveal if the TCC is the culprit here, this will reduce parts/guess work.
Old 09-04-2008, 07:59 PM
This is something I would like to do as well. Do I have to take it in, or is there a cheaper way similar to the Autozone method? Does the scanner plug into the OBD or is there another port. Mine is the last year before OBD II became standard, would this be a problem?
Old 09-04-2008, 08:28 PM
A990 racer
A specialized scanner program is required, most trans shops have this, no AZ is useless here.
