Noise following front brake job
2002 Astro AWD
About two weeks ago I replaced my front pads and had the rotors turned. And about one week ago I started hearing a noise from them when braking with light to moderated pedal pressure. Sometimes the sound is very regular as if related to the rotating hub/rotor. And sometimes it appears more random or eratic. If this sounds familar to anyone can you clue me in to the problem and/or solution you encountered? I have removed the wheels and examined brakes, only to find the caliper pins are tight. The pad clips are very snug and holding them in place. I can grab the caliper with my hands and slide it a little. This brake job was the first time I have used that quieting goop that you spread on the back of the pad that goes against the piston. All input is greatly appreciated. Thank you, Donny Baugh |
Re: Noise following front brake job
see if its a problem after the brakes get warmed up.it maybe a bad rotor or machined improperly.
