Old 08-10-2008, 08:41 AM
briang0 briang0 is offline
Brake line replacement?
I have to replace the front and rear brake lines on my 94 silverado. The rear seem pretty straight forward. My question is on the front one of the lines is coiled up like a spring. I have to replace this one do I have to coil the new line the same way? It looks like it goes into the anti lock module does it have to be that way because of this. If I do how can I form the coil. I couldn't find anything about it in the chilton manual. Any comments.
Brian
Old 08-10-2008, 10:39 AM
j cAT j cAT is offline
Re: Brake line replacement?
Brian
I believe it is best to recreate the coil as best you can the tubing will bend fairly easy use a round object to rap around..
this coil is used to smooth out the ABS pulsations when the ABS is activated....removal may cause a poor brake effort if ABS is sensing slide..
Old 08-10-2008, 08:17 PM
wafrederick wafrederick is offline
Banned
Also get a roll of brakeline instead of 3 seperate lengths of lines and it comes in rolls of 25 foot.Recreate the coil and do it right.To make the job much easier,Mastercool makes a hydraulic flaring tool in a kit and it is much better,faster than the manual one and costing about $400.00.
Old 08-11-2008, 08:40 PM
come on now this guy is gonna spend 400.oo for a flare tool....????
no way ...
The best way to do this is to buy a lifetime warrantee flare tool manual type about 50.oo....then after you complete the job tell them it's junk....
get your money back...
if you gonna keep vehicle use the s/steel lines...
Old 08-11-2008, 09:39 PM
Banned
You save time with the one made by Mastercool.The manual one takes longer.My father has the Mastercool flaring tool and has not used his maual set since switching to it.The manual version stays in the toolbox drawer collecting dust.
Old 08-11-2008, 09:56 PM
jd-autotech jd-autotech is offline
i have bought coiled brake lines like for under master cylinder at the dealer
Old 08-12-2008, 06:21 PM
gremlin96 gremlin96 is offline
wow both dealers i have used say thay can not get brake or fuel lines factory bent. i have had to buy striate lines. the fun part is thay still had the napa stickers on them. you know ware i went, a trip to napa.
to do the coil use a mag light. the size is just about right. just pull steady and wrap it around.
you can get custom brake lines made if you find a auto parts store that does hydrolics repair. thay will have the tools to do the bending and to put the ends on. just take your old line with you and have them match it up on lenth
Old 08-12-2008, 07:12 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Do the coils as gremlin96 suggested. If you don't have a flashlight you can use a beer bottle, stair picket, etc., ... anything that's round and rigid.
If you don't have a pipe bending tool you can use a small diameter spring to bend up to 90 degrees. Where ever you buy the brake line probably has various diameter springs around 6" long, just find one with 3/16" or 1/4" inside diameter, or whatever diameter you brake line is. Slide the spring onto the tube before bending. This will keep the tube from collapsing when bending. Just make sure you do the flares after bending or else you won't be able to remove your spring. You don't need the spring for the coil as the tube won't collapse due to the large diameter.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
