Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-02-2008, 01:05 AM   #1
The Fast Forester
The Fast Forester's Avatar
A/C Issues
2001 Ram 1500, 5.9L, 94,000 miles. Towed the boat, topper, 4 people and their gear about 1,000 miles round trip in some pretty hot weather across the Great Plains and Sandhills. A/C started acting up, noticed the accumulator (cannister on firewall) was really wet (maybe frozen at one point?). Had to turn the A/C off occasionally when it stopped blowing cold, then turn it back on and it was fine. Do I need a charge of fluid, or might there be another issue I need to look into? FYI, temp guage on truck ran cool the whole way, less than 200. Thanks for any input.
The Fast Forester is offline   Reply With Quote
Old 08-02-2008, 10:35 AM   #2
angus10
Re: A/C Issues
You need to check the pressure on the low side.
98 Ram 1500 4x4
Flowmaster American Thunder W/super40
angus10 is offline   Reply With Quote
Old 08-02-2008, 10:43 PM   #3
The Fast Forester
Re: A/C Issues
Not sure what you mean angus?
Old 08-03-2008, 06:00 AM   #4
angus10
Re: A/C Issues
You need a gauge to check the pressure at the low side AC port,(the one closest to the accum/dryer.When it starts blowing hot air is the compressor running?
98 Ram 1500 4x4
Old 08-03-2008, 11:46 PM   #5
jdmccright
The RustBuster
jdmccright's Avatar
Re: A/C Issues
Manifold gauges are better at trying to diagnose A/C problems as you can see the pressure difference between the high and low sides and how they change as the system runs.
That being said, my first guess would be that you have water condensate in the system and it is icing up in the accumulator and/or orifice tube or causing it to get clogged.
Easiest way would be to have a technician check it out, but if you're interested in learning, Haynes makes a decent repair manual specifically for A/C systems...it's info overload in the beginning, but very handy knowledge. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
jdmccright is offline   Reply With Quote
Old 08-03-2008, 11:59 PM   #6
The Fast Forester
Re: A/C Issues
Thanks for the info fellas, I appreciate it. I took the boat to storage today (about 45 minutes round trip), A/C worked fine. Shut it off for a few minutes while unloading the boat. I'll get this checked next time I take it to the shop. Thanks again
