Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 01-16-2009, 08:41 PM
bmudgett bmudgett is offline
2003 intrepid wiper motor or switch problems
My wipers and sprayers stopped working. I checked the fuse, relay, changed the wiper motor(wasn't it) I do I know if it is the switch or something different?
Old 01-16-2009, 11:12 PM
discnik discnik is offline
Re: 2003 intrepid wiper motor or switch problems
Get a multi-meter and wiring diagram for your wiper switch and see if you have voltage into and out-of your switch. This will at least help you narrow it down.
Old 01-17-2009, 10:13 AM
The switch includes the turn signals and high beams which continue to work but no wiper or sprayer action
Old 01-17-2009, 10:01 PM
If it is a tilt column, check the multi function switch connector to see if any wires have been pulled loose. Press each wire toward the connector to make sure that they are firmly seated in the connector.
