i am working in a 2000 new beetle with a 2.0 the car started missing alot and had misfire codes for all cylinders and a cam sensor code after many tests i replaced the cam sensor it did not change a thing i also replaced the coil no matter what i do it resets the cam sensor code if anyone has any ideas i would greatly appreciate it
Re: Please Help cam sensor code
I'd check all these things. Good Luck. |
if the timing belt was just done check the cam gear reluctor ring on the cam gear for being bent or broken.
ASE Master certified and VW certified. Just here to help all check engine light codes ------> http://www.automotiveforums.com/vbul...d.php?t=328630 |
sounds like the timing is off just enough to set the fault. sometimes when you do a timing belt on these cars and you have the timing off just a tooth it will set a code, but still run fine. if its off a lot, itll cause it to run rough and set the code. if its off even worse, it could cause valve damage. but it sounds like yours might have just jumped time. set it on TDC and look at your mark at the crank and the mark at the cam gear.
