Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Problem Diagnosis
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-11-2005, 09:45 AM
Hellbilly Hellbilly is offline
Cleaning out my Motor...
My Blazer is comming out of the shop today..
I had new V Seals and the Heads cleaned....I told my mech to just fill it back up with cheep oil cause i wanted to clean out the whole thing..
What product would youll recomend to flush the whole motor out? (Something that can be got in a autoparts store...I gota trip comming tommorow and I dont have time to order)
and whats the best procedure?
Old 03-11-2005, 01:10 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: Cleaning out my Motor...
See my thread on Loud Lifter Knock for the exact procedure, however, to answer your question, I used the "GUNK" brand. Cost about $2.50 USD for approx. 35 ounce bottle. The bottle says 5 minute Flush but I would leave it in 30 minutes AT IDLE ONLY.
DO NOT REV THE ENGINE WHILE THIS STUFF IS IN THERE.
Old 03-11-2005, 03:06 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
I will be test piloting AutoRX for my truck.
Check it out here:
http://www.auto-rx.com
This stuff has been proven to work miracles and I need one for my sludged up 4.3L.
Old 03-11-2005, 03:30 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
gunk works fine makes it good and black
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 03-11-2005, 03:39 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
GM has a good cleaner. Its called I think engine crankcase cleaner. I have had extremely good results with it. SAme idea as all the rest, pour it in, run the engine at idle for a certain amount of time, and drain it. Its very strong, and can be picked up at a GM dealer parts outlet.
Old 03-11-2005, 03:59 PM
Big Tall Dumb Ass
Here is what I did:
Buy the "Gunk" brand engine cleaner and the cheapest 5W-30 oil on the shelf. Drain the oil and install a new (Cheap) filter and add the new cheap oil along with the Gunk flush being carefull not to overfill the system. Start and run the engine 30 minutes AT IDLE. Drain the the system again and dump in a 1/2 qt. of castrol GTX 5W-30 while the drain plug is out to flush any remaining cheap oil/flush out. Install the oil pan drain plug, then fill the system with Castrol 5W-30 and a brand new AC-Delco Filter. You should not have any more lifter noise.
Old 03-11-2005, 06:28 PM
Bodaggit Bodaggit is offline
Send a message via ICQ to Bodaggit
So cleaning one out like that doesn't hurt the bearings in the engine or anything? I've always been a little hesitant about cleaning out my engine. I have a little over 80,000 on mine right now, and I don't think it would heart it to be cleaned out. I get a little lifter noise sometimes after starting it when it's been sitting for a while, and I always use Valvoline 5w-30 motor oil. Maybe it's just timr for a cleaning.
Old 03-11-2005, 08:02 PM
BlazerLT's Avatar
AF -Advisor
Do you use an orange Fram filter?
Old 03-12-2005, 02:12 AM
Re: Re: Cleaning out my Motor...
no, I usually get a pure one.
Old 03-12-2005, 02:33 AM
BlazerLT's Avatar
AF -Advisor
I would do an Auto-RX cleaning cycle.
Product can be found here:
http://www.auto-rx.com/
This stuff is amazing.
Old 03-12-2005, 07:43 AM
mumser101 mumser101 is offline
Auto-Rx is a safe alternative to solvent-based engine flushes. The 5 minute solvent flush may break off chunks of sludge and clog oil passages. Auto-Rx is a slow process, taking 1500 miles to dissolve layer by layer of sludge.
Take a look at a test by a skeptical user who thought Auto-Rx was snake oil. Go to www.rms13.com.
There is also a discount coupon code floating around: ARXOF.
Old 07-22-2008, 12:23 PM
roofcleaningtampa roofcleaningtampa is offline
Cleaning is important.
I cleaned mine too.
In my situation, a big difference was made by the cleaning.
Apple Roof Cleaning Tampa 813 655 8777
Old 07-24-2008, 10:55 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
This thread is over 3 years old. Please refrain from posting in old threads.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Closed Thread
