Need Help
I have a 1994 Chevy Caprice Classic LS with a 4.3 V8 engine. The Odometer reading is 196,000. Only thing ever changed as long as I had this car was spark plugs,wires, and fuel pump. When I pull off it has a bad hesitation . On early mornings when I pull off it is ok for about 1 or 2 miles down the road. After that occurs thats when it starts the hesitation, and as it starts that I almost have to hold it to the floor to pick up speed. When I am at normal cruising at about 50 to 60 miles per hour thats when the hesitation also occurs even in a lower gear I still feel the hesitation. Need immediate help on what can be causing this. Thanks, chevysboy |
Registered Offender
![]() Join Date: Mar 2006
Re: Need Help
If the Opti is the original unit, it might be time for a new cap and rotor. Plan on a water pump at the same time.
Confoundingly Lucid
Re: Need Help
and one thread usually does the work of 3 in your case!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Re: Need Help
have u checked your fuel filter that might be a cheap place to start
#5 | ||
Re: Need Help
