Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Suspension and Drivetrain
Suspension and Drivetrain Discuss suspension, and drivetrain performance modifications here.
Old 06-13-2008, 09:52 PM
Birddogz28 Birddogz28 is offline
question
Just bought a 95 Z28, nice to have the F-body back home!! Car runs strong Auto and the tranny seems strong. When I take slow turns (like at a cul-de-sac I get a strange rub (not clunking) in the rear, happens both ways. Feels like rubber (maybe suspension?) tires are brand new. Any thoughts? Its only 3 days old and I will be taking it to my mechanic in a week or so as I have a 3 month warranty on it.
Old 06-25-2008, 08:46 AM
Re: question
Any thoughts out there?
Old 06-25-2008, 03:56 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: question
Does it have stock rims? Or does it have an aftermarket set?
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 06-25-2008, 07:09 PM
Re: question
Stock Rims. Brand new tires (put on the day before I bought the car).
Old 06-25-2008, 08:37 PM
blindeyed's Avatar
eBay aDdict™
Re: question
Check to make sure there is sufficient clearance between the wheels and the wheel wells. Also, this may sound stupid, but make sure all the lug nuts are nice and tight on the wheels. I had 3 fall off on me somehow and wound up riding around on a wheel that was only secured with 2 lug nits. Every time I took a slow turn, like you described, it made a rubbing sound. Was the wheel wobbling back and forth on the studs. I couldn't figure out what it was until a friend pointed it out. Was the last thing I would have thought of checking. Like I said, sounds stupid, but it's worth checking out if you already haven't.
- Jason
Old 06-26-2008, 03:27 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: question
my guess is the rear axle bearings.
Old 06-26-2008, 03:56 AM
72chevelleOhio 72chevelleOhio is offline
Re: question
Originally Posted by Birddogz28
Feels like rubber (maybe suspension?) .
WTF?
I had the clutch discs come apart inside my limited slip that intermittently caused the differential to lock the axles together while cornering. Like trying to drive with a "spool" instead of a diff.
If its the tires that are making the noise.....
Old 06-27-2008, 10:39 AM
99Firebird3.8 99Firebird3.8 is offline
Re: question
I had a 2002 SS 35th anniversary convertible, and it did the same, now yes the rims are bigger and bigger tires, but it did it cause someone put on shocks that werent strong enough to bear the load of any turn. So check your shocks, make sure they are giving you enough clearance to turn with the weight shift!
