Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-17-2008, 12:45 PM   #1
ihgrad
Oil Additives for Slowing Leaks
I curious as to opinions of this stuff. I have a 1996 Camry and looks like the rear main is leaking- I was hoping to slow it down and postpone the repair for awhile. Any thought about additives or other suggestions?
ihgrad is offline   Reply With Quote
Old 06-17-2008, 03:56 PM   #2
DFBonnett
Re: Oil Additives for Slowing Leaks
Over the years, the few times I used the stuff brought mixed results. It never did any harm that I could notice.
FWIW
YMMV
DFBonnett is offline   Reply With Quote
Old 06-17-2008, 05:05 PM   #3
RIP
AF -Advisor
RIP's Avatar
Many use additives, many avoid them like the plague. It's one of those questions where you'll get many and varied opinions. Another choice would be one of the new "High Mileage" oils. They have an ingrediant that helps seals swell to prevent leaks in older cars. Could this "ingrediant" be the same as what is in some additives? I wonder.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
RIP is offline   Reply With Quote
Old 06-18-2008, 09:56 AM   #4
jdmccright
The RustBuster
jdmccright's Avatar
I'm on the fence about it myself. I buy the high-mileage oils but I really wonder if causing old, brittle, rubber seals to swell is really a good thing to do...won't they just crack? If the seal is just worn, maybe it works and it can't hurt to try, but a true age crack in the seal won't be magically repaired by an additive.
The only oil additive I've seen that worked was Bardahl's No Smoke for stopping the bluish smoke from the tailpipe...not directly relevant to this topic, but it works by mainly thickening the oil, so maybe it might help reduce the leaking...in theory. But I wouldn't dump many different additives in at once. They might work against each other and cause sludge. Try one and drive it until time to change the oil. If it didn't work, try another after the oil change, and so on.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
jdmccright is offline   Reply With Quote
Old 06-18-2008, 11:53 AM   #5
somick
somick's Avatar
I do agree with all the posters above, but I doubt that rear main seel will expand and stop leaking. This is rather a mechanical failure.
I have tried "stop leak" in the past with a front seal and it did not work. Had to replace it.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
somick is offline   Reply With Quote
Old 06-18-2008, 03:06 PM   #6
Mike Gerber
AF -Advisor
I am not a big fan of additives, other than fuel injection cleaners poured in to the tank. I doubt whether an additive will work to stop a rear main seal leak, but feel you have little to lose by trying. $5 compared to the cost to replace the rear main seal sounds to me like something worth trying. Like jdmccright suggested, try only one stopleak product at a time.
Good luck.
Mike
Mike Gerber is offline   Reply With Quote
Old 06-18-2008, 03:22 PM   #7
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Don't use an additive that will radically change the viscosity of the oil. I have no data, but it is a change that could prove really costly.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 06-23-2008, 10:34 AM   #8
jdmccright
The RustBuster
jdmccright's Avatar
I forgot to mention I tried a "stop leak" product (not Bardahl's brand) for my front cam seal. It didn't work...turns out the seal had cracked, so it never had a chance. Good thing the stuff was "guaranteed to work"...I'll be sending in my receipt for my money back!
I had the timing belt changed by a shop the first time...bet they didn't change the seals then because they were quite brittle when I popped 'em out. For the $15 spent on new seals, I'd change 'em along with every timing belt change. As for the rear crank seal, well.... I guess unless it's a significant leak, live with it until the tranny needs an overhaul. Something abt spending $500 to change a $5 seal grates on me.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 06-23-2008, 09:45 PM   #9
ihgrad
Yeah, my friend always refers to cost of access- do what you can when you have things apart or it'll cost you more in the long run. Had that happen with my van- should replaced the coil pack while I had the engine apart... oh well, $400 lesson there... grrrr. Hopefully I WON'T have to overhaul the tranny any time soon, buuuuut... is 250k miles too much to ask of a transmission?
Funny thing about this leak: I don't see oil leaking any more- not even a drop for about a week anyway- after the 1st 100 miles after putting it all back together (it had been sitting completely drained for about 8 weeks). Any comments on that?
