Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 05-22-2008, 11:14 AM   #1
DD Blue
2001 Fuel Pump Electrical Circuit
My wife calls me and says the Bravada won't start. Turns over vigorously but sounds like it's out of gas. The tank is 3/4 full. She calls back 20 minutes later and says it starts but runs "odd". I tell her to take the car home and I'll take a look at it.
When I get home, I turn the ignition on and listen for the fuel pump. Sounds normal, so I turn it over and it starts right up. I turned the car off and did the same thing twice more. On the third start, the car just shut off about 5 seconds after start. On fourth try, I didn't hear the fuel pump. I haven't heard run it since.
So I check the ECM/fuel pump fuse - looks good. Swaped the horn relay with the fuel pump relay (they're identical). Horn still works so it must not be the relay. I dropped the fuel tank and replaced the fuel pump assembly (not fun at all ). I'm pretty sure hoses and electrical connections were reconnected properly and are undamaged.
I even charged the battery but I don't have fuel pump operation (no noise, no pressure). What now?
DD Blue is offline   Reply With Quote
Old 05-22-2008, 12:11 PM   #2
brcidd
brcidd's Avatar
Re: 2001 Fuel Pump Electrical Circuit
check the gray wire at the fuel pump connector.. should read 12v with KOEO (key on engine off) for 2 secs- are connectors burnt?, melted?, good ground? New fuel pump - is it aftermarket?- or an OEM replacement pump? Did you have to splice in any wires? Has new pump ever ran- did you bench check it first?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 06-10-2008, 05:42 PM   #3
DD Blue
I ran a bypass to the pump using straight battery power. Pump worked. Then I did a continuity check of the ground wire to the pump and then the positive. Both checked out OK. So I hooked everything back up and started the car. No problems since.
The only thing I can figure that I did wrong is that I seated the connector just enough to complete the sending unit/fuel gauge circuit but not enough to get juice (or ground) to the pump.
Old 06-11-2008, 09:44 AM   #4
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Thanks for the update, hope it's fixed for the next several years.
Chris Stewart is offline   Reply With Quote
