Go Back   Automotive Forums .com Car Chat > Car Audio
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music.
Old 05-28-2008, 04:27 PM   #1
vinnym86
vinnym86's Avatar
Send a message via AIM to vinnym86
AUX input not working properly
I have a Kenwood KDC-MP7028. It has a 2-channel RCA Aux. Input in the rear. I ran a splitter to convert it to 1 RCA male from 2 females, then a converter from RCA to 3.5mm male. I plug in my iPod, and it neglects half of one of the 2 stereo channels, or an entire channel completely. I've triple-checked wiring, even used new wires, splitter, converter, still the same faults in audio. any reason why this is messed up?
The most beautiful thing we can experience is the mysterious... He to whom this emotion is a stranger, who can no longer pause to wonder and stand to rapt in awe, is as good as dead: his eyes are closed.
vinnym86 is offline   Reply With Quote
Old 05-28-2008, 04:34 PM   #2
pre98zetec
pre98zetec's Avatar
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: AUX input not working properly
if you ran a converter to convert 2 into 1 then you just made it mono, you need to get a plug that plugs into the females that has a 3.5 jack on it, walmart sells them in the home audio section or over by headphones.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
pre98zetec is offline   Reply With Quote
Old 05-28-2008, 07:05 PM   #3
vinnym86
vinnym86's Avatar
well the head unit itself has a right and left channel RCA input, if i get a converter from RCA to 3.5mm on each channel, i'd still need to join them. I've done that, too, using a 3.5mm splitter. I can see how i turned it into a single channel sound, but, aren't headphone 3.5mm plugs stereo? the only 3.5mm cable i can find has only 1 wire running from both male ends, which works fine in other head units with a front aux input
Old 05-28-2008, 08:20 PM   #4
PaulD
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
you have to look on the metal plug of the 3.5mm adapter. You probably have one that only has one insulator - to seperate into tip and sleeve, this is a mono adaptor. The stereo one will have 2 insulators and three distinct metal section - tip, ring and sleeve. Look at it closely before you buy another one.
PaulD is offline   Reply With Quote
Old 05-28-2008, 10:48 PM   #5
pre98zetec
pre98zetec's Avatar
even if he had a stereo 3.5mm he just converted a set (red,white) into 1 RCA, which converted it to mono right there. You need a plug that takes both red and white and converted it down to 3.5mm jack.
-Josh-
Old 05-29-2008, 07:51 PM   #6
PaulD
Audio Guy
ok, I see whay you're saying. He needs a single cable that has 2 rca males on one end and a stereo 3.5mm jack on the other.
Old 05-30-2008, 05:08 PM   #7
vinnym86
vinnym86's Avatar
i have never seen a cable that does that, 2 RCA males to 1 3.5mm. I could just use 2 converters from RCA to 3.5mm, making 2 3.5mm, then find a stereo 3.5mm splitter.
thank you for your help
Old 05-30-2008, 07:46 PM   #8
pre98zetec
pre98zetec's Avatar
your making it way more complicated then it needs to be....
Just go to walmart and look for this :
http://www.crutchfield.com/S-UhsZT2X...px?I=043183190
Or order it there, but there only like 2 dollars at walmart..
-Josh-
Old 05-31-2008, 02:19 PM   #9
vinnym86
vinnym86's Avatar
damn i am making it harder. i told you i never saw a cable like that, but i've always only checked Radioshack, Circuit City, and this car audio shop who are theives to the unknowing.
