Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-28-2008, 09:41 AM
Automotive_Fanatic's Avatar
Automotive_Fanatic Automotive_Fanatic is offline
new to the scene....
whats up everyone... new to the dsm scene but old to the tuner scene... I just piced up a 91 eagle talon AWD turbo... and well I am not sure were to start. the cat who originally had this car getto fabed the exhaust and pretty much everything else... dont get mewrong with the new turbo and the oddly done exhaust plus the few other things he has done this car pulls hard as hell.... but like I said its all been half assed and well I want it all done right. he accually took the exhaust off of a dually deisel and fabed it onto the car... also the turbo when you get into the high rpms the turbo surges up high.. again not sure why it does it...but as long as I keep the rpms lower then it will boost fine... anyways does anyone know of any good reputable companies to get parts from? and that are fairly priced? thanks again for the help... oh and I did search but I like user opinion... on this one... places that you have delt with personally..
Old 04-28-2008, 09:53 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: new to the scene....
Welcome to the DSM world.
Firstly, do a tune up. Plugs, wires, oil, fuel filter, air filter, coolant flush, compression test... just make sure everything is in good running condition. Also do a boost leak test. That will find a ton of problems.
What turbo are you using? Stock? Sounds like you may have boost creep if it "surges up high". Do you have a boost gauge? If so, what's it reading.
As for exhaust, it all depends what you're looking for. SBR, eBay... there's a ton of DSM sites around. I'm sure others will post more since I can't remember anymore.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-28-2008, 09:56 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Vendors: DSMTuners.com has a list of preferred "sponsoring" vendors that have done us and the website well over the years.
Boost issue in high RPMS: Could be that the exhaust is too free-flowing (yeah, I know how that sounds) and you're getting boost creep. If the turbo is internally gated, porting the WG hole and/or getting a larger flapper can help eliminate this.
Welcome, and don't be afraid to use the search even though you like the opinions...here, as well as other sites. The last one of these cars rolled off assembly about 10 years ago, so most everything have been tried/reviewed/etc.
Kris
2012 Genesis Coupe 2.0t
Old 04-28-2008, 12:16 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 04-28-2008, 12:24 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
As for vendors, I'd recommend getting your stuff either from Modern Automotive Performance or Extreme PSI. The guys at MAP are all good, knowledgable guys and their prices are fair as hell. Anything I want in the future will come from them and if they dont have it I'll go with Extreme PSI.
You should do some reading up on these cars. Theres a lot of really good tech articles on DSMtuners as well as upgrade paths that you should check out. VFAQ has a lot of really great stuff as well, as does our tech article section here and the 1000AAQ site.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-28-2008, 01:31 PM
he said the turbo is off of a evo 4? I know it was an evo but yea its still stock...as far as the boost goes, it will run up to around 15 psi which is close to 6k the serge up to 25 psi. im affraid that with it surging like that it will run lean...
Old 04-28-2008, 01:34 PM
im also worried that if it sures like that wont rthat make it run lean?
Old 04-28-2008, 01:42 PM
If you're surging that high, you're risking your motor. Can you snap a pic of the turbo?
Kris
Old 04-28-2008, 03:56 PM
I called the guy and he said its a big 16g turbo that is on there now. he also said it has a 30mm wastegate on it but the flange is opening up fully.
Old 04-28-2008, 04:37 PM
Thor06's Avatar
Jizzed In My Pants
Actually, the wastegate flapper physically will go all the way open, but unless he has the wastegate actuator mod done the flapper is only opening to like 45-60 degrees or something. Best thing you can do is port the flapper hole and stuff and getting the 34mm flapper probably wouldnt hurt either. Also, I think porting or getting a better flowing o2 sensor housing would help.
Lando's right too, 25 psi is very not good on a stock car. Definately keep it low until you can get it fixed.
Old 04-29-2008, 07:29 AM
yea I have pretty much been babying it. would it make a difference if I changed the waste gate? and would it help if I down sized the exhaust? he has 4" on there now...
Old 04-29-2008, 09:34 AM
david-b's Avatar
Dave is THAT guy
4"!! Damn that's too big. 3" will do plenty. I agree with Lando on this one.
75 Monte Carlo
Old 04-29-2008, 09:50 AM
JoeShmoe's Avatar
Holy shit 4". That is way too big to do anything good for that car.
Old 04-29-2008, 11:55 AM
Thor06's Avatar
Jizzed In My Pants
An external wastegate will be the easiest and "best" fix, but also the most costly. I personally think that if you are going to go with an external WG then you should do it manifold mount style, which means you will need a new manifold as well as the WG and a dump tube.
Old 04-29-2008, 12:14 PM
ok what would be a good combo as far as the wg, manafold, and dump? the only manifold that I can find it a gay pace setter...
