Go Back   Automotive Forums .com Car Chat > Chevrolet > Beretta
Old 10-06-2007, 05:12 PM   #1
eggbirtt
91 3.1 Will start if I give it gas but won't idle
If I give it gas, it will start. It will not idle though. It has a brand new fuel pump, filter, lines etc. I pulled it in the garage to replace the carpet, disconnected the battery, replaced the carpet and now it won't start nor stay running. Please help. Thanks in advance.
eggbirtt is offline   Reply With Quote
Old 10-06-2007, 07:42 PM   #2
anomaly_va_1976
Re: 91 3.1 Will start if I give it gas but won't idle
My 93 had a similar problem.... The IAC valve was stuck... are there any codes set by the ECM?
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < [email protected] >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
anomaly_va_1976 is offline   Reply With Quote
Old 01-11-2008, 02:55 AM   #3
anomaly_va_1976
Just a thought.... the ECM could've gotten zapped when you reconnected the battery... my 93 had similar problems and turned out the ECM was bad, loading the engine up with fuel at idle.
Old 01-26-2008, 06:31 PM   #4
loosenut74
loosenut74's Avatar
Send a message via Yahoo to loosenut74
Idle Air Controller... about a 60.00 dollor part that takes less the ten minutes to change on a Beretta...
and there is a idle relearn procedure it MUST go through to run right again...
Removed by Moderator
loosenut74 is offline   Reply With Quote
Old 04-20-2008, 02:42 PM   #5
tomtom123
check the TPS
tomtom123 is offline   Reply With Quote
