Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 08-31-2007, 11:16 PM
masonryteach masonryteach is offline
Exclamation can't remove crankcase pulley bolt
trying to replace timeing belt on 94 honda civec ex but cant get crankcase pulley bolt off. is this bolt reverse threaded? can anyone give me advice on getting this bolt off?
Old 09-01-2007, 02:17 AM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Re: can't remove crankcase pulley bolt
the bolt is not reverse threaded u have to use an impact gun with at least 100psi and hit it three or four times disconnect main motor mount to lower motor and use a floor jack to lower the motor and then u can impact it.. but when u go to put it on make sure not to impact it too hard because u can spin the pulley on the belt good luck
Old 09-02-2007, 05:43 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
no need to lower the motor... i reach mine perfectly... and all you need is a 700ft/lb impact gun and a compresor will 120psi in the line.. it wont stand a chance.. however DONT use that gun to put it back on.. itll never come off.. i use a smaller, shitty impact with about the spec torque rating on the bolt and it goes right on.
Old 09-07-2007, 03:44 AM
wiseguy01's Avatar
i find it easier because the timing belt is more exposed and when u have big hands u need all the room u can get
Old 10-02-2007, 12:26 AM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
Red face Re: can't remove crankcase pulley bolt
I drove my car to a neighborhood mechanic, had him zap it off then put it back on, not so tight. Charged me $20
And while we're on the subject, my timming belt seems to have some slack on the front side. i replaced the tensioner and all, could the slack come from not properly aligning the TDC marks on the cam and crank?
Old 10-02-2007, 02:18 AM
wiseguy01's Avatar
completely normal if u did everything right as long as one side has tension
Old 10-02-2007, 06:06 AM
Kind of a Big Deal
a little slack is ok on the front side... did you remember to turn the crank 3 teeth bacward after you set the backside tension? that will eliminate most of your slack.
Old 10-02-2007, 03:27 PM
Yeah, Three Teeth Couter Clockwise. Thanks Guys.
Old 11-19-2007, 10:05 PM
ThiRteeN's Avatar
ThiRteeN ThiRteeN is offline
Send a message via AIM to ThiRteeN
would a huge fucking breaker bar work to get the nut off? i dont have an impact gun....
Definition of Ultimate Rejection:
-When your hand falls asleep while jerking off
-98 Civic DX....R.I.P.
-96 HX...........work in progress
Old 11-19-2007, 10:36 PM
wiseguy01's Avatar
no it will not because u are relying on the torque of the impact gun to take the bolt out if u use a bar ur just gna turn the pulley and the timing belt wont move hence timing reset and it still wont work so air compressed impact only man
Old 11-20-2007, 09:46 AM
Kind of a Big Deal
Depending on how tight it is... if you put the car in 1st gear, and have a friend press the brakes... then take a braker bar with a long extension... rest the end of the extension on a jack stand to steady it... it MIGHT come off that way
Old 11-22-2007, 12:16 PM
ThiRteeN's Avatar
Oh, cuz i saw that u get one of those strap things to keep the pully in place while u use a breaker bar.....but if i can find one ill use a gun...
Old 11-23-2007, 10:23 AM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
i got one of those strap things from jegs cuz i dont have an impact..mines a little different looks kind of like a coilover adjuster..goes onto the flywheel to hold it in place..biggest waste of money..it bent trying to hold it..but i had my motor out of the car so i could lever against the crank..but it can be taken off without an impact..but if the motors in the car id definately do it to save yourself a headache..
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 03-27-2008, 04:10 PM
lethinhtran lethinhtran is offline
I was told this crankcase bolt on my 1999 Honda CRV is reverse threaded. Is it true?
Old 04-21-2008, 05:33 AM
B16 SiRII's Avatar
B16 SiRII B16 SiRII is offline
Send a message via AIM to B16 SiRII
Honda sells a tool that holds the pulley in place for those that have no access to air tools, looks something like this:
Alot of companies make them actually. Although you'll never use it more than a couple times.
Air tools on the other hand...
You may know me as Fakter1 on other forums.
