Old 04-13-2008, 05:06 PM
donna13063 donna13063 is offline
Post high beams won't work
We recently acquired a 91 Honda Civic Hatchback (manufactured In Canada). There is a problem with the high beams that we can’t resolve—they won't work but the low beams work fine. We've checked everything we can think of; all fuses, bright lamps, switch, relay for head lamps are all okay, and the wiring seems to be intact and grounded.
Before we take the car to a shop to have them trace down the problem, I wanted to check to see if anyone has any suggestions.
We do not have an owner’s manual for this car. We’ve located one fuse box under the steering column and one relay/fuse box next to the battery. Is there another box anywhere we need to locate? Have you heard of anyone else with this same problem?
Old 04-14-2008, 12:16 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: high beams won't work
since wiring is not my forte, i'll let someone answer, but i would highly suggest you invest the money into an manual
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 04-14-2008, 02:06 PM
KoDKingVegeta KoDKingVegeta is offline
My old civic had the same problem. What I had to do was replace the whole turn signal/light assembly. Fixed the problem.
1989 Honda Civic DX Hatchback
*STOCK
Twisted Motor Sports
The Cell Games
^--Help Revive an old forum, Come Join
-=flash to the future: (three months) "As stock prices continue to climb for superglue... ppl are frantic.... *static* KoDKingVegeta buys the whole market out *Static* fix *static* dashboard from *static* UK... *end of flash to the future*=-
Old 04-14-2008, 03:47 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Trace your way back starting from the headlight wires right at the bulb. There are only the two fuse boxes and the one under the dash is what your looking for. Also each high beam is individual once it leaves the switch, meaning theres a fuse for left and right (only one power source coming in, but 2 going out), and a relay to match. So if neither of them are coming on id put good money on the switch. but also check the power coming into the switch. this is all easy to do once you get the cover off of the steering column, it just pops off and theres a ring type clamp behind the steering wheel holding the top and bottom together. 3 screws hold the bottom cover on.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
