Old 02-27-2003, 04:08 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Double wishbone suspension
I know it's the best sporty setup. Can someone tell me why?
And also, how does one go about tesigning the setup? I mean the lenghts of the lower/upper A-arms, and also the length of the forward and rear rods in the a-arms. And also all sorts of angles (vast question, I know). I'm just very very curious to learn as much as possible, hope you don't mind my questions (and I have a lot of them to come! )
Thanks,
Alex
Old 02-27-2003, 11:45 AM
FYRHWK1 FYRHWK1 is offline
Send a message via AIM to FYRHWK1
Double wishbone suspension is the best setup because it reacts to bodyroll less then any other type of independant suspension, they also let you have a large amount of vertical travel without the wheels angle (camber) being changed, the C5 corvette fo example, it has 0 camber change through 95% of its vertical travel, it uses a double wishbone setup. the other types of independant suspensions are trailing & semi trailing arm, swing axle, and multi link, they just use different ways of controlling the wheel and how they attatch to the structure of the car.
Old 02-27-2003, 04:23 PM
454Casull 454Casull is offline
I wouldn't say it reacts less... I'd say that the wheels maintain more surface area on the road.
Body roll isn't the only thing double wishbone suspension is good at. Bumps and stuff are easily absorbed too.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 02-27-2003, 04:28 PM
ales's Avatar
Forza Schumacher
So is it as good for luxury cars as it is for sporty cars?
Old 02-27-2003, 07:33 PM
Yes. Better handling benefits us all. But double wishbones do take up more space than, say, MacPherson struts, and leg room is definitely higher up on the Good Things list for luxocars than sports cars.
Old 03-02-2003, 01:45 AM
ales's Avatar
Forza Schumacher
So when designing this kind of suspension, what are the benefits/downsides of having 1 wishbone longer than the other?
Old 03-02-2003, 05:35 AM
Deakins's Avatar
Deakins Deakins is offline
The camber angle remains nearly unchanged when you have body roll.
The downside is the chamber angle change at bumps.
The ringing of the division bell, have stopped...
AF User Guidelines
Old 03-02-2003, 12:14 PM
911GT2 911GT2 is offline
Nonparallel unequal length arms just happen to have less camber change (larger contact patch).
This should help explain: http://autozine.kyul.net/technical_s...handling_1.htm
Some people deserve to have their vocal chords ripped out. Oh yeah, and American beer is like having sex in a canoe...it's fucking close to water.
Proud member of www.automobileforum.com
Mod -www.autoworldforums.com
Old 03-03-2003, 06:45 PM
by reacts less I mean that the contact patch stays relatively unchanged, although it does happen, and bumps are just sudden vertical travel.
87-91 Camry Rear Suspension Parts F/S nohablaingles Classifieds 0 07-02-2009 11:22 AM
5-Link vs. Double wishbone tc3house Engineering/ Technical 4 08-06-2005 12:12 AM
macpherson, double wishbone? silvia15 Engineering/ Technical 4 05-14-2005 02:23 AM
double wishbone vs. struts OoNismoO Engineering/ Technical 15 01-16-2004 10:42 AM
