Old 02-26-2008, 09:04 AM   #1
darin00
95 chevy lumina fans don't work
I have a 95 chevy lumina and the fans are not working, I put new relays in and a water pump and i bleed the system and put a new Coolant Temperature Sensor, and Thermostat, still the fans don't come on. someone told me it might be the Pressure In Compressor Switch but i look all over for it and i can't find it can someone help me please?????
darin00 is offline   Reply With Quote
Old 02-26-2008, 09:28 AM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: 95 chevy lumina fans don't work
The fan(s) will only run when engine temp calls for it, or the A/C compressor is engaged...
how long are you letting it run? does it overheat?
The fans won't run much, if at all, in colder weather...
...empty gun rack.
Old 02-26-2008, 09:51 AM   #3
brcidd
brcidd's Avatar
And "W" car fans "WAIT" on head pressure to rise to 175 before they come on-- so just turning on the a/c does not guarentee fan operation either--- engine temp need to be about 227 degf to request the fans as well--- used to be they would come on when you jumper your ALDL to check for SES codes--- but I am spoiled by my Tech I-- which I can command fans on with to test them---
Why do you think you have a problem?? boil over? or just a higher than normal temp gage???
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 02-26-2008, 11:04 AM   #4
darin00
I just put some head gaskets on it and its overheating.
Old 02-26-2008, 11:19 AM   #5
jeffcoslacker
Are the radiator and upper hose hot to the touch when it starts going over to hot?
You try letting it run, select full heat on the dash, with the bleeders and cap open at operating temp? There can be some real stubborn air after a complete empty...
Also if you have a compression leak you'll probably see endless steady air bubbles from the bleeders...
Also there are two CTS, you replaced the one for the ECM, yes? The other is for the guage..
...empty gun rack.
Old 02-26-2008, 11:26 AM   #6
darin00
yeah the radiator is hot and the upper hose, on the heat on the dash gets hot but not like it should, and I did replaced both CTS and the ECM. But the low coolant light does come on too
Old 02-26-2008, 06:16 PM   #7
j cAT
unplug the fans connector and place 12v across input to fan... does fan run..... check all wiring to fans and grounds....in winter the fans normally will not come on unless the vehicle idling with hood closed for a long time....I would suspect that as stated air in coolant is interfering with water pump operation and by leaving fill cap off with vehicle at operating temp this will help get the air out..... also look for coolant purge valve at thermostat goose neck and open to release air.....
Old 02-26-2008, 07:16 PM   #8
jeffcoslacker
Originally Posted by j cAT
unplug the fans connector and place 12v across input to fan... does fan run..... check all wiring to fans and grounds.....
good point...lotta times after major surgery a ground wire taken off hides and doesn't get put back on....
...empty gun rack.
Old 02-27-2008, 03:56 PM   #9
darin00
ok I try the 12v across input to fan and the fans work but when I unhook the Coolant Temperature Sensor and start the car they come on and the car runs ten times better but I just bought that temperature sensor not to long ago so I know its not bad and I also bleed the system agine with the fill cap off I think its air free.
Old 02-27-2008, 06:37 PM   #10
j cAT
you must replace the ECT this is mounted at the thermostat this info then goes to the computer and not the dash guage.....Engine Coolant Temp...........computer will then put fans on when coolant at thermostat is about 230deg. f
Old 02-27-2008, 07:20 PM   #11
jeffcoslacker
I was given the wrong CTS from a parts store once...made the car run rough as hell (ECM was reading it as temp at bottom limit, full rich)
Never assume the part is not the problem...especially if you just installed it and then had problems.
my favorite saying is "If I had a nickel for every customer who ever said "It can't be [insert part name], because I just had it replaced.."
That was the first thing I checked, and 90% of the time, that was the problem...
...empty gun rack.
Old 02-27-2008, 07:26 PM   #12
j cAT
this is very possible that he was given a defective sensor but i believe is is unaware that one sensor goes to gauge and the other at thermostat goes to computer that drives the fans....
Old 02-28-2008, 03:22 PM   #13
darin00
ok I bleed the system for along time and then i let the car set and Idle for along time and when it started to overheat the fans kick on. So is that normal for it to overheat when set idle for a long time?
Old 02-28-2008, 03:30 PM   #14
j cAT
what is happening when it starts to overheat? does the coolant boil ? is it because of the reading of the dash temp gauge position.....lets say its boiling but the dash gauge is not max and you have the coolant cap securely on so that 14psi can build up in the radiator...then i would say that the cap is no good because coolant should not boil at 14psi at 230deg f...
the higher the pressure the higher the temp for water to boil in Boston water boils at 212 In denver its 187........
Old 02-28-2008, 03:36 PM   #15
jeffcoslacker
My '97's fans turn on when the gauge is about 3/4 of the way up the scale, but these gauges are pretty meaningless...every one reads different.
The question is, did it bring it back down quickly once the fans ran, or did it just sit at that temp or climb higher?
Idling, it should bring it back down to normal within 20-30 seconds or so...
...empty gun rack.
