Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 08-11-2006, 03:57 PM   #1
mountie1982
mountie1982's Avatar
P0134 Code
My 97 blazer is running rich and has set the check engine light. I bought a scanner and it reads a P0134 code. THe blazer puffs a black cloud of smoke under heavy excel like going up hills or merging on to the hwy. I cleaned the MAF but it still does it. Any ideas?
2006 Dodge Ram 1500 Quad
Why Dodge it when you can RAM IT?
1964 Vw Baja 1600
mountie1982 is offline
Old 08-11-2006, 08:30 PM   #2
mountie1982
Re: P0134 Code
I played around with the conectors seeing if one was lose reset the computer then tried it again. Code went off again and now there is a P1406 code too. WTF!!!!!!!!!!!!!
I search the net and found that the p1406 code means "EGR Valve Pintle Position Circuit". I am not sure what thats means. I guess that means the EGR needs cleaning????
1964 Vw Baja 1600
Old 08-13-2006, 03:17 AM   #3
mountie1982
Re: P0134 Code and a P1406 Code
Well its looking like I am on my own here. I really need some advise. I have cleaned the egr valve which didnt look too bad. I have replaced the o2 sensor in front of the cat. I looked for a vacuum leak but couldnt find one. Reset the computer and its still setting codes. P0134 P1406. Is there something I am missing???
1964 Vw Baja 1600
Old 03-02-2008, 09:11 PM   #4
BlackTeg98
Send a message via AIM to BlackTeg98
Re: P0134 Code
my mom had a 95 blazer and she needed the EGR valve replaced so many times. there a problem with chevys. egr valves take any extra exhaust and puts it back through the system which makes the truck run cleaner for emissions and for better gas milage. i would get a new egr valve and change the 2nd o2 sensor. the 2nd one usually throws the code because its the one that needs to have a cleaner read because of your CAT filtering the exhaust.
<a href="http://enjukuracing.com/index.php?ref=18&affiliate_banner_id=5" target="_blank"><img src="http://enjukuracing.com/affiliate_show_banner.php?ref=18&affiliate_banner_ id=5" border="0" alt="EnjukuBanner2"></a>
BlackTeg98 is offline
Old 03-02-2008, 10:33 PM   #5
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
Re: P0134 Code
Its good that you have info on the problem to share but this thread is a year and a half old. please check the dates before posting.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
ZL1power69 is offline
Closed Thread
