Go Back   Automotive Forums Car Chat > Chevrolet > Corsica
Old 03-08-2008, 01:29 PM
chak5050 chak5050 is offline
Surging at Idle
Need some advice, or someone who's had this problem. I have a 88 corsica with the 2.0L. The car surges when idleing, more so in drive but alittle in park. As soon as I push the gas it goes away it seems. It gets more noticable when the car is warmed up. Feels like the car wants to die, but luckily it doesn't. So far I'll taken the throttle body off, cleaned it, cleaned the IAC. I have also replaced spark plugs, fuel filter, and fixed a small vacume leak. I think it's either the IAC or the TPS but I'm not sure how to test them.
2000 Nissan Maxima SE, 3.0L, 5speed
1988 Chevy Corsica 2.0L
Old 03-08-2008, 01:45 PM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
Re: Surging at Idle
Any DTC?
03 GMC Sierra 100k
05 Infiniti G35 150K
10 Mazda 3 Hatchback 110K
16 Infiniti Q50 Red Sport 34K
Old 03-08-2008, 03:16 PM
Re: Surging at Idle
nope none
Old 03-08-2008, 04:19 PM
Headnsouth's Avatar
Re: Surging at Idle
Check for vacuum leaks.
03 GMC Sierra 100k
Old 03-14-2008, 04:22 PM
rhandwor rhandwor is offline
Re: Surging at Idle
Take some carb cleaner and spray along the intake manifold if it smooths out you probably have an intake leak. You can pull the idle air control valve and clean it. A leaking egr will cause problems. Spray also along any gasketed surfaces.
