Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-01-2008, 07:51 PM
fieds87 fieds87 is offline
Transmission Trouble, Help
I have a 1991 Mitsubishi Eclipse. Recently i have noticed that the car runs only in 2nd gear. It won't shift into any other gear. and when i put it in reverse it jerk hard. I checked my transmission fluid and filled that up but no help there. i read somewhere else about a speed sensor going bad and that can cause the problem. but i dunno if that is right or not. if anyone has any advice, if would be much appreciated. Thanks in advance.
Old 03-02-2008, 11:20 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Transmission Trouble, Help
Do you have a check engine light? I would think that you would get one if the speed sensor went bad. It could be the tranny control unit also.
I would try changing the oil and filter on the tranny before replacing any parts.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-03-2008, 12:22 AM
steviek's Avatar
steviek steviek is offline
my speed sensor went and I never got a CEL but I had a MT I'm assuming this |AT
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 03-03-2008, 01:31 AM
Holset powered 420a
Did the speedo just stop working? That would tell him whether his is working or not.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-03-2008, 08:08 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
How would it get to 2nd gear if it didn't move enough to upshift from 1st if it was an AT?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 03-03-2008, 09:43 AM
Holset powered 420a
It goes straight into second i guess.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-03-2008, 01:12 PM
steviek's Avatar
yeap speedo was just 0 all the time and I didn't put any miles on the car for almost 6 months
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 03-03-2008, 01:41 PM
JoeShmoe's Avatar
How was your tranny running then? Soudns like a transmission cable was disconnected IMO.
Old 03-03-2008, 03:44 PM
yea my speedometer works. that's why i figured it wasn't that. but it happened as i went to work so probably before i parked it, it got stuck in 2nd. but thanks for the advice all. i will see how that works.
Old 03-03-2008, 04:19 PM
Holset powered 420a
The VSS only effect auto trannies. He has a manual so all the VSS does is operate the odometer and speedo. I have no idea what you mean by tanny cable. Sounds like your referring to the older cars that used cables to drive the speedo.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-03-2008, 04:38 PM
JoeShmoe's Avatar
I thought ours were cable driven? Shows how much I know.
