| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
what does it mean when the radiator light is shown on the cluster?
My fluid looks good and my fan is hooked up I dont see problems |
I found out it means my coolant is low
I checked my coolant ands its full all the way up to the overflow I wonder if its the sensor. I could not find any sensor. I will look harder if anyone knows let me know! |
Re: 2000 mustang shows radiator light on cluster
Could be that you need to fill the reserve to the full line. I know my fiancee's car will send off lights if the reserve isn't full. Also could be a ad sensor.
1969 Cougar 357w & TKO - 475hp |
The reserve is full to the top! |
If there is a light there is a sensor.....should be located on the overflow tank probably near the bottom. Is it coming on when the car is at operating temp or at all times? may want to check and make sure it isn't running hot if it only comes on after driving. Hope this helps
When everything is said and done, there is always more said than done. |
