Old 01-21-2008, 12:48 AM   #1
purepower77
HELP - Messed up my rear disc brakes
I need some help... I spent a good part of the day doing the rear disc brakes on my '93 Lumina... I had to take the calipers off and bring them inside to get those damned pistons in (yeah, I read the other threads... helped immensely, especially since I didn't realize just how much more complicated the rear would be). Anyway, I finally got everything back together and topped up the brake fluid...
Now, the pads won't really set. I have to press the brake pedal 3 times, and on the third they feel fine. The first two are just nothing but air. So, the third works, and then I'll give the car some gas and move, say, 10 feet, and then have to press the brakes 3 times to stop again.
Could I just have a stupidly large amount of air in the brake system and have to bleed them? Could I possibly have damaged the pistons? (I don't think I could have buggered BOTH of them, but I guess it's possible) Aside from the air, I can't really think of what it could be, but I'm pretty much an amateur.
Can anyone give me some ideas to try out?
Thanks a lot.
purepower77 is offline   Reply With Quote
Old 01-21-2008, 02:30 AM   #2
16th hippy
Re: HELP - Messed up my rear disc brakes
you didn't mention that you bled the system. if you didn't, then you do have air in there. it MUST be bled out!
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
16th hippy is offline   Reply With Quote
Old 01-21-2008, 07:01 AM   #3
john51md
Thanks a lot.
Maybe i am thinking of a different car, but dont you have to use the E brake to adjust those pistons back out?
john51md is offline   Reply With Quote
Old 01-21-2008, 08:47 AM   #4
purepower77
No, you're right, I didn't bleed the system. I'll try that. Would be great if that solved the problem, which I think it probably will since the brakes do 'harden up' eventually.
Thanks a lot.
Old 01-21-2008, 11:19 AM   #5
j cAT
Thanks a lot.
if you must remove caliper pistons simply disconnect the caliper pins pads and with the hose attached and rag around piston step on brake pedal this will push piston out rag will protect piston from getting damaged then repair and install. do one side at a time bleeding is common sense. make sure brake res does not drain out all the way.........
Old 01-22-2008, 07:20 AM   #6
john51md
Honestly, those rear calipers... if you have the money, its better and easier to replace them on these cars. Worse design i ever messed with.. ya know i heard before that later in years Lumi's went back to drum brakes for awhile, and the first ones to get them would interchange on a older lumi. But, as i said, i "heard" this.
