Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 01-23-2008, 02:04 PM   #1
spirithorse17
Ponchonutty...or others..save me with Passlock and Electrical!
Hey, Poncho -
I hope you don't mind me sending you a PM. I've been reading your posts the last several years on the PK2 problem and even compiled a binder for both my dealer and Chevy that contains a good deal of your posts. Am hoping you might be able to direct me here:
After years of this PK2 problem (security light coming on while driving, stranded in bad areas, strange things happening like lights going out in the rain, etc.), I thought incorrectly that my replacement last summer of the alternator (stupid me) might have solved the problem.
Since the alternator replacement last summer, I only had one brief encounter with the Security Light. Two days ago, the car battery was found to be completely dead. I was able to jump it and drove straight to the dealer. One interesting note - the seats were all moved to a strange position upon finding the dead battery.
The dealer also found, upon walking to the car in the morning, that the seats had moved on their own. Could not find problem with the battery.
I drove three blocks to another dealership (to look at Toyotas!), decided to turn the ignition off, and of course, the car would not start until three tries. The start can be classified as a "weak, sagging start" and came to this gradually after the alternator replacement. However, it has found this weak start status over the years...always. Battery was replaced a little over a year ago (at only 51000 miles).
Now, the dealer has it again and is unsure how to proceed with the battery issue. They want to say it is a "weak cell" in the battery.
What can I tell them? I am hoping not have to resurrect my 3 inch binder and start the whole Chevy case file threatening, etc.
Thanks for anything....and if you want me to post on the board, I can do this to help others learn. Wanted to go to you first, though.
spirithorse17
2000 Chevy Blazer
57366 miles
Haunted for years by Passlock and Security Light
spirithorse17 is offline   Reply With Quote
Old 01-23-2008, 02:45 PM   #2
sickcallawayc12
sickcallawayc12's Avatar
Re: Ponchonutty...or others..save me with Passlock and Electrical!
Replace the ignition switch?
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
sickcallawayc12 is offline   Reply With Quote
Old 01-31-2008, 05:45 AM   #3
randy78
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
had passlock issues on a 98 achieva we have
replaced ign lock twice
had the instr cluster repaired twice
went ot the dealer three times
all to no avail
the security light would return and disable the fuel injectors again, sooner or later
we got sick of this un repairable passlock issue and i snipped the black yellow/wire from the ignition lock assembly and it has been fine for a year now
passlock is one of the most problematic systems ever
it rates way high on the scale of frustration of passlock equipped vehicle owners
nothing but troubles with it
security light flashing and injectors not firing is the dead giveaway that passlock is FUBAR in a vehicle
if so then good luck fixing it
chances are that you wont, and GM cant either
cut the wire
and it will be fine
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
randy78 is offline   Reply With Quote
