Old 02-03-2003, 01:46 PM
dumpedhatch's Avatar
dumpedhatch dumpedhatch is offline
ecu code ?
my motor blew a month ago. so I just installed another d16a6. And when I take off from a start it boggs down then when I give it more gas it starts going normal. The ecu is giving a code 1(oxgen content). so do I just need to repace the o2 sensor.
Old 02-03-2003, 01:54 PM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
it could be the oxygen sensor.
also it could be a fuel problem. If your engine is running lean/rich it will set off the oxygen sensor code because the sensor is reading outside of its range. take your plugs out and inspect them. if they are black, you maybe runing rich. if they white, you are probably running lean.
check the oxygen sensor with a multi tester. im not sure what resistance it is supposed to be, but your haynes manual will tell. if it is bad, replace it, but if not, i would start by checking your fuel filter, injectors, and fuel pump.
hope this helps.
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
Old 02-03-2003, 05:25 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
double check all your sensors. that happened with the sedan. it ended up being as simple fix as switching 2 plugs.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 02-03-2003, 05:52 PM
ecu code
do u remember which sensor it was. I had to rewire some of my wires because of being so old and greased up. somewhere I might have switched them around.
