Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-01-2002, 06:54 PM
iceiso iceiso is offline
Send a message via AIM to iceiso
turbo vs SC question (no, not a comparison again)
alright, i have a question. pretend we have a civic that makes 300HP with a turbo charger, and one that makes 300 with a supercharger. PRETEND that they weigh the same and have all the same parts.
my question is, would the one with a 300 SC run faster than the Turbocharged one? because, i mean, you have 300 HP to the wheels rather than waiting for a turbo to kick in, so is it common sense to believe that the Supercharged one would run faster? because it has 300HP for "longer"?
haha, i know that superchargers don't make balls to the wall power like turbochargers, but just a question. thanks for any replies!
Old 12-01-2002, 10:22 PM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
ALL other things being equal(which would almost be impossible) I would say that yes, that would be correct. The supercharged car would more than likely have a better torque graph, giving it harder acceleration sooner and for longer than the turbo'd vehicle. Not positive though...
There's no replacement for displacement...No, not even a turbo.
Old 12-02-2002, 09:46 PM
chad174 chad174 is offline
well, thats a good question. but just because the s/c boosts quicker, does not mean it will be faster. the s/ced car will be faster off the line and in lower revs, but the turbo car will be faster in higher revs once it's spooled up. i'm not sure which would be faster, but i just wanted to put in my 2 cents that the turbo car will pull harder in the top end.
Old 12-04-2002, 01:54 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
All things being equal the SC would get the hole shot, but the turbo would pull ahead eventually.
Just because it is a SC does not mean that it would make 300HP to the wheels and the turbo would not. They would both still be 300HP at the crack and have some loss through the drive train.
Old 12-04-2002, 01:57 AM
hybridsol's Avatar
hybridsol hybridsol is offline
Send a message via AIM to hybridsol
agreed, lag spool enter's into the equation as well.
Old 12-04-2002, 04:56 AM
Self's Avatar
Why would the turbo car pull ahead later? If they both still have the same peak horsepower of 300, and assuming that they both have that peak hp at the same engine speeds(revs), then the turbo car would never pull ahead eventually. The SC'd car would take off quicker because it makes more boost sooner, and the turbo car, while catching up some would never even catch up to the SCd car, let alone pull ahead of it. Understand what I'm saying?
Old 12-04-2002, 10:31 AM
Polygon's Avatar
The Red Baron
Yes, I do. The thing is that different engines react differently with a S/C or T/C setup and in most cases I have see the S/C win off the line and the T/C pull ahead in the end, and sometimes the two cars had the same engine. Then again I don't know all the variables, just an observation.
Also if you will notice that S/C is used for drag racing and T/C is used to on the salt flats to set land speed records, once again, just an observation.
Old 01-26-2003, 06:13 PM
SleeperCivic SleeperCivic is offline
I think the S/C would win. It would peak to the 300hp before the turo, all things being equal, equal launch times and such. The S/C would get through the 60' faster. I've seen cars lose to drivers making less HP that could get through the 60' faster.
'04 SRT4 [Black] - 13.46 @ 102.9 (2.09 60') - R.I.P. 1999 Civic EX Turbo
.:ATP Up Pipe .:HKS SSQ w/Purple Insert .:K&N Typhoon CAI
.:Greddy Full Auto TT .:Greddy Profec B Spec II EBC .:Greddy Catch Can
.:AGP Billet Wastegate
.:Stock Ass-whoopin Installed
Dyno Proven - 234.6whp / 250.9tq 13.66 Video
Old 01-26-2003, 10:31 PM
Self's Avatar
Please try and refrain from dragging posts nearly 2 months old up from there depths
Old 01-27-2003, 07:23 AM
Why? It wasn't locked... You did the same thing when you first got on this board to get your posts up......
Old 01-27-2003, 08:37 AM
Self's Avatar
No I didn't...And that's most DEFINITELY NOT what this forum is about. It's NOT about getting your posts up. When I first joined, 3 years ago, I didn't go around whorring multi-month old threads just so I could get my post count up.
Old 01-27-2003, 12:11 PM
Polygon's Avatar
The Red Baron
Also being here isn't about getting your post count up. Post counts don't earn any respect around here, it is all about what you type, not how much you type.
Old 01-27-2003, 08:58 PM
Dude, I didn't say that's what I'm doing. The post is still open and I had a comment to make. If you've got a problem with that, go moderate at another forum and quit singling me out. Thank you.
Old 01-27-2003, 11:43 PM
Self's Avatar
I'm not singling you out. I say something to everyone who needs something said to them. I'm just advising you that when you see a post months and months old, don't drag it back up to post outdated information that is at this point irrelevant at best. And I think that if you have a problem with my moderating...YOU can go post somewhere else. Thank you. And if you have a personal problem with me, or with my moderation, or with my so-called singling you out, PM me
P.S. And I quote "You did the same thing when you first got on this board to get your posts up......"
So don't tell me you didn't drag this thread up from the abyss just to raise your post count.
Old 01-27-2003, 11:53 PM
I didn't, you've been here a month longer than me and look at the post difference. BIG difference, so obviously I'm not a post whore.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
