Old 12-25-2002, 12:49 PM   #1
cvcracerhond
non-vtec to vtec
is it possible to put a zc head on a d series engine? i have a dohc zc head non vtec and i was wondering could i put type r cams on it and is it possible to make it a vtec?
cvcracerhond is offline   Reply With Quote
Old 12-25-2002, 01:18 PM   #2
hondacivic4drlx
hondacivic4drlx's Avatar
Send a message via AIM to hondacivic4drlx
i dont think so becuase the vtec distrubutor is different then the non vtec one. i dont think the parts will fit on it becase the ears on the distributors dont line up. i recently swaped a d15b in my hatch and wanted to see if i could use the distributor off my old engine and it didnt fit. but i know you could put the head on there but no vtec, and plus where the soleniod go?
and the pressure switch?
:silly2: :silly2: :silly2: :silly2: :silly2:
hondacivic4drlx is offline   Reply With Quote
Old 01-06-2003, 11:41 AM   #3
91civicDXdude
91civicDXdude's Avatar
Send a message via MSN to 91civicDXdude
a DOHC d series head will not fit onto a SOHC d series block without extensive machining.
you cannot make a non vtec engine vtec by adding different cams. you have to have the vtec selenoid and the vtec mechanisms in the head. If you really want to go VTEC, get a d16z6 or d16y8 head and mount it on your block. as far as the distributor goes, you can modify the distributor to fit so you can still adjust ignition timing.
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
91civicDXdude is offline   Reply With Quote
non vtec / vtec? jay1985 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 07-08-2004 04:01 PM
Non-vtec/vtec engine swaps Parsalian05 Prelude 0 09-01-2003 05:02 PM
H23 Non Vtec+vtec HiRvNPreLude Prelude 5 07-02-2003 01:23 AM
Sohc Vtec head 2 A Non Vtec Block lowcivicman99 '71-'87 Civic | CRX 1 06-25-2002 12:43 AM
Vtec Head on Non-Vtec? H22-Civic Si '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 05-19-2002 08:59 PM
