Go Back   Automotive Forums .com Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 11-18-2007, 04:37 PM   #1
import4life
Trailing arm
I was wondering if anyone here knows where I can buy a New trailing arm except from the dealer. i'm looking for the rear trailing arm because of bad bushing. i know i can replace just the bushings but was curious how much one would be
import4life is offline   Reply With Quote
Old 12-10-2007, 10:22 AM   #2
MrWrongsalive
Re: Trailing arm
You can buy one from the dealer, a good place to start is majestic honda, their prices are good. One thing though that bushing is a nightmare to replace. The best method I have seen is to cut the old bushing's sleeve out of the arm, and drop it at the machine shop to be pressed back in. Energy Suspension makes a polyurethane insert that requires you to gut the old bushing (remove only the rubber) and can be pushed in by hand (plus a couple other hands). I've done both and found that the Energy Suspension method is the easiest and helps with handeling.
MrWrongsalive is offline   Reply With Quote
