Go Back   Automotive Forums Car Chat > Pontiac > Grand AM
Old 12-10-2007, 10:25 PM
kge420 kge420 is offline
Reset service engine/Trac off
I was working on my son's 1999 Grand Am and I unplugged the Trac Off switch. I ran the car with it disconnected and the serv eng/trac off lights came on and won't go off. The car ran perfectly prior to this. Question: Can the code/problem be cleared by disconnecting the battery. I don't believe this is a mechanical problem. My thinking is along the lines of re-booting a computer. Thanks, Keith
Old 12-11-2007, 08:26 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Reset service engine/Trac off
Welcome to AF.
Why did you unplug the ETC ??
If thiers a trouble code(DTC) and one of the service lights are on,
you will need an abs capable scan tool to clear the code, thier's no other way!
1999 Grand Am SS 3.4 OHV
Old 12-11-2007, 08:43 AM
I unplugged the on/off switch so I could move the radio bezel out of the way. Again, will disconnecting the battery reset the computer? Thanks, Keith
Old 12-11-2007, 12:00 PM
Oh I see, if that's all that you did then after a few engine cycles it should shut it's self off.
If it doesnt after a week, I'd get it scanned and have the code cleared and see if it comes back.
Old 12-11-2007, 12:31 PM
Thanks, will do. I scanned the service engine and got a P0105 and P0108. Any suggestions? I have a friend with a transmission shop and I will go see him if the trac off light doesn't clear.
Old 12-11-2007, 05:13 PM
p0105 - MAP or TPS cicuit malfunction
p0108 - MAP sensor high input
So yeah, sounds like you have several issues here.
Clear them and see fi they come back, but it sounds like you might have a connection/circuit bad somewhere.
Old 12-12-2007, 07:30 AM
Do you know of any connectors in the area of the radio, ignition switch. I was working in that area installing a remote starter for my son as a Christmas surprise. While I was working I was careful not to disturb anything that didn't need to be. I am heading to my friends to get the ABS scanned and will report back. I also will disconnect the remote start and see if that clears the issues. Again, thank you for your interest in this matter; Keith
Old 12-12-2007, 03:10 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
I'll chime in. Did you energize BOTH ignitions and accessory wires? That'd be the only thing I could think that would cause a weird code like that. I've done a ton RS on these cars and never had one through a code other than what you'd get if you start it with that switch unplugged but after about 3 ignition cycles it'd go away.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 12-12-2007, 04:05 PM
As long as the battery was disconnected when you were installing the remote starter, I dont see anything being disturbed by that.
Probly is just a coincidence the service light(s) came on, and its probly a wheel speed sensor. Another typical problem with these models.
Old 12-12-2007, 06:01 PM
Here are my results from todays scan: no ABS or ETS codes. Engine still shows MAP/BARO trouble P0105 and P0108. Remote tart is a Bulldog model RS1100 with a 791 security bypass module and a GM6 T-harness. The remote start works fine but I have these problems. ponchonutty could you explain "energizing both start and ignition" I used the recommended harness to try and avoid any troubles. Thanks again, Keith
Old 12-12-2007, 06:02 PM
edit: ignition and accessory kge420
Old 12-12-2007, 06:50 PM
Doesn't sound like anything you could have done is the problem here.
I'd say from the dtc's your MAP sensor if malfunctioning. I'd test the Map circuits and check the vacum line to the MAP.
Thier's a test/replace procedure in the Tips and Maintenance subforum.
Hope that helps.
Old 12-12-2007, 08:08 PM
I will check the MAP sensor and report back. xeroinfinity, you are being a great help with this problem. Thanks again, Keith
Old 12-12-2007, 08:16 PM
xeroinfinity, I did not disconnect the battery when installing the remote start. I didn't want any trouble with the radio as I don't have the security code.
Old 12-13-2007, 07:10 AM
Well, double check that t-harness. I seen some that were screwed up. Unhook it and see if the car behaves normally. Those Bulldog units are at the bottom of the barrel units. Good luck with it!
Pioneer 4900mp
Orion C63 Coax rear
