Go Back   Automotive Forums Car Chat > Ford > Escort
Old 12-02-2007, 07:41 PM
iward iward is offline
Thumbs down disconnecting battery while engine is running
Will any damage be done if a battery is disconnected while the engine is running?
Thank you.
Old 12-02-2007, 08:13 PM
Davescort97 Davescort97 is offline
Escort guy
Re: disconnecting battery while engine is running
Yes, with the ignition on and high idle you can blow relays, radio and other electrical equipment. You need the battery to absorb amperage and voltage spikes. Some say this is a test to see if the alternator is charging. Instead, measure voltage at the battery while the engine is running. Should be about 13.8 volts. Don't test your alternator by disconnecting the battery.
Old 12-08-2007, 02:48 PM
chrisanthony chrisanthony is offline
yea not a good idea..turn the car off first..then disconnect the negitive first then the positive
