Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-16-2007, 08:30 PM
92talontsiawd 92talontsiawd is offline
Send a message via AIM to 92talontsiawd
fuel pump
ok i was wondering.. i picked up a 92 eagle talon tsi awd.. and it is pretty much stock except for a full exhaust, intake, boost controller, and a new head.. i was wondering if i could safely run 20-22psi of boost with the stock fuel pump or if i need an aftermarket one.. and if there is anything else i would need to safely run 22psi let me know.. im planning on getting a FMIC and a header so any info would help cause im new to dsm's, i had a camaro.. so im alittle lost with boost haha thnx
Old 12-16-2007, 10:22 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: fuel pump
Yes, and no.. Your stock wired FP will most likely not keep up with the demands of your ECU's fuel tables, and you most certanly will experience fuel cut (air-cut) once your ecu see's 2.55g/rev. It's been a couple years sence i've had any experice with a 14b. I can't remember at what airflow I started seeing my stock 2g pump run out of steam, or exactly where I peaked 2.55g/rev and at what psi.
Invest in a pocketlogger or Dsmlink if you plan on being serious about tuning or fuel managment.
DSM geek
Old 12-16-2007, 10:27 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: fuel pump
Why are you so set on 22 psi? You might want to do some research before cranking the boost like that or I guarantee you will fuck some shit up.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-16-2007, 10:52 PM
Re: fuel pump
ok thnx.. im not saying im gunna constantly run 22psi.. i just wanna make everything safe for when i go to the track and IF i wanna run 22psi.. but right now its running like 18psi and theres no problems..
Old 12-17-2007, 12:54 AM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: fuel pump
How do you know there are no problems? Do you have a datalogger to prove it? You won't really feel anything going wrong. But I assure you that 18 is too high on a stock pump especially if it isn't rewired. I wouldn't run over 16 even with a 190.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 12-17-2007, 03:09 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: fuel pump
IIRC, the 2g pump rewired is barely enough to cover a 14b at full steam. A 1g pump certainly won't cut it. Most poeple can get away with the stock regulator on a walbro 190 pump however, and they're less than 100 bucks. With a pump and a logger and an FMIC I'd run 22 psi all day on that POS, FWIW.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
