Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-08-2007, 03:14 PM
outthere2's Avatar
outthere2 outthere2 is offline
Fan Speed Dial
My fan speed dial only works on High.
Anyone know what the problem could be?
99 Camry CE V6.
Blows smoke on startup. I had a garage look at the compression to diagnose weather it was the rings or valves.
When it came back the fan speed dial only worked on high.
Dan.
Old 11-08-2007, 04:23 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Fan Speed Dial
For the fan speed, check the blower motor resistor pack. This is the most common part that fails and results in the loss of the lower fan speeds. Follow the wiring from the blower motor (under the passenger side of the dash) and you will see the resistor pack in the blower motor housing. It's usually held in by 1 screw. Remove the wiring connector to it and then remove the screw and take the resistor pack out. Take it to the dealer to match it up with the new part. I believe this is a dealer only part. It should run about $50-$60. It really shouldn't be related to doing a compression check. I would have to assume it's just a coincidence.
Mike
Old 11-08-2007, 10:13 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Fan Speed Dial
A common reason for smoke at startup is worn valve guide seals. One odd thing. My 87 did the same thing for a couple years. I would see blue smoke for 2 to 3 minutes at startup. Not a lot of smoke but, enough for me to notice it. No smoke the rest of the day. Then after a few years it stopped.
You might see your resistor block in the factory manual listed in the "Factory Service Manuals" thread at the top of the forum.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 11-09-2007, 11:06 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Fan Speed Dial
There is a post in the FAQ thread related to blower motor resistor replacement.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-24-2007, 07:11 AM
outthere2's Avatar
Re: Fan Speed Dial
Thanks all...
I will let you know how I make out.
