Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 11-14-2007, 06:28 AM
djmann02's Avatar
djmann02 djmann02 is offline
Question Left turn signal/left side hazard lights won't flash
My wife has an 04 Honda Accord and the other day the left side turn signal would not work. The greeen arrow on the instrument panel will no longer light up either. Same result when you turn on the hazards. Left side is DEAD! However, when you use the remote to unlock the doors, the bulbs illuminate as if nothing is wrong indicating that all the bulbs are functional plus they have been checked as well. Furthermore, I put a meter on the rear left turn signal and it showed no life. What and where is the problem?
Old 11-14-2007, 12:23 PM
somick's Avatar
somick somick is offline
Re: Left turn signal/left side hazard lights won't flash
This looks like a classic conditon of a bad bulb. I would start with a new one.
Since you said that you tested output with a meter, look for a bad contact or a broken wire.
It may also be a bad ground.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 11-14-2007, 04:13 PM
djmann02's Avatar
Well, both bulbs, front and back work. And the bulbs will light up when I hit the remote to unlock the car which means that the wires can't be damaged, right. Could it be some type of fuse, relay, etc. that I am missing. I didn't see a fuse though for the turn signals?
Old 11-14-2007, 07:18 PM
somick's Avatar
I drive 99 LX and there are two fuse pannels. But I still do not think that this is a fuse prolem. It does not hurt to check them though.
Some bulbs have two filaments. If it works when you lock your car there is still a possibity that the over filament is dead. That is why I suggested to try a brand new bulb.
Good luck,
Sam
Old 11-19-2007, 05:03 PM
djmann02's Avatar
It was a $6 relay according to the mechanic. Bulbs were fine. Pass this info along.
