Go Back   Automotive Forums Car Chat > Ford > Probe
Old 09-04-2007, 03:14 PM
Brenda101 Brenda101 is offline
Unhappy 1995 Probe GT NEED HELP
Can anyone give me some pointers with this problem, i'm having troubles when i give the vehicle throttle, it begins to bog out when i give alot of throttle, but if i just lightly depress the accel pedal i can pick up come rpm otherwise it bogs, and wants to die out, also my idle sits lower than usual and the problem all began when i was driving out to vancouver island 300 kilometers away ???? Please help
Old 09-07-2007, 10:54 AM
taillight taillight is offline
Re: 1995 Probe GT NEED HELP
First pull the trouble codes and see what the computer doesn't like. Then look for any vacuum hoses off or cracked. How long has it been since you had a tune-up ?
Old 11-17-2007, 06:04 PM
C. Cleve C. Cleve is offline
Hi, You MOST likley have a vacumme leak, OR the LARGE hose going to the throttle body is cracked, The flex hose, Take a GOOD look, See Ya, Clay..
Old 11-19-2007, 07:50 AM
octagon octagon is offline
I had a 93 that was doing exactly what your's sounds like it's doing. I found a crack in the bottom of the flex hose that joins the air cleaner to the throttle body. I was 100 miles from home when it happened, so a piece of duct tape fixed it until I got to the wreckers for and intact one. The other thing it could be is a crack in the insulator at the plug end of the plug wires. If the Bakelite is cracked or if it is oil soaked from a leak in the valve cover gasket, it can short out against the side of the valve cover and cause the car to miss fire. I would start looking for a vacuum leak first, but check the plug wires while you are at it. Good luck
Some days you'er the dog, and some days you're the hydrant.
