| Performance Anything you ever wanted to know about boosting the performance of your Cavalier. |
Some of you may know i bought the TTR upper mount replacement for my 2200, so instead of letting my old upper insert just collect dust and be useless I offered it up to another member here on the board. I'm putting this up for him to see how to install the mount and for others who may consider this mod...
First of all, you need to support the engine because the upper mount actually holds the engine up a great deal. So support it ( DON'T LIFT IT) at any of these red locations i have marked. I use the one where the red arrow is since my floor jack pad is large. DO NOT USE YOUR OIL PAN and on a level surface. If not, when you remove the main bolts the engine wall fall backwards and outta alignment. ( Been here before) ![]() Stock mount looks like this. ![]() Gather your goodies to install and these tools plus a flat head screw driver. 13mm Deep well socket 15mm ' ' ' Dish Soap ![]() Now since i was removing this for Derek the mount will be installed for the next steps while i remove the parts needed to install this sucka. 1) Get your coolant resovoir out of the way. There is one 10mm bolt that holes that in place along with against the side of the fender wall. This is where you need the screw driver to carfully manuever it out of its spot. Also remove the plastic bracket that holds the A/c return lines to the collector. Its the plastic part in the pic shown above. 2) Loosen with 15mm socket all 3 nuts around the base of the mount. Loosen, do not remove. 3) Use the same 15mm wrench and remove the 2 main engine bolts that attach to the engine. This is where you need to be careful to make sure your jack is in place and start backing one bolt little way out, and keep going back and forth from bolt to bolt while removing them. You will see a gap start to form between the head of the engine and the motor mount. This is fine and normal. Expect anywhere from 1"-1.5" of gap to form. The stock mount has ALOT of weight on it and the rubber is just going back into a neutral position.....onwards.. 4) Finish remove the 3 nuts from the engine mount and completely remove the mount from the vehicle to work on it. 5) Mount with top plate removed.. ![]() 6) There are 2 -13mm bolts below that that need to come out. ![]() 7) This will leave the open slot needed to install the insert. Get your soap and lather her up real good as when they are new they are going to be a very snug fit and need it. When derek gets mine, it has already been broke in and won't be that way. But i would still use some soap buddy. ![]() Fully seated ![]() ![]() ready to go back into the vehcile... ![]() retork everything to spec.
Please don't PM me with your J-body Issues. Post appropriately in the forums, and I will toss my opinion in your thread if I have anything to help. - Thanks! 2006 Chevrolet Trailblazer 2010 Glastron GT 205XL |
Re: Upper Engine mount insert Install (2.4L, 2.2OHV, 2200 wit pics)
Doesn't look like rocket science, just a matter of following instructions, lol
wicked thanks lots i never got ne instructions how to put ion my new RK sport mounts. seems pretty easy.
Should be in your mail box tuesday. No mail tomorrow, sending it regular mail is getting it there the same time as it would have been sending it priority. So you got it 1st class mail and i got an ice tea from the gas station across the road with the left over change. Ha ha.
looks pretty damn straight forward, i just ordered the insert & the lower dog bone mounts from RK Sport for my fiance's 2.2 Cavy...her mounts are trash
-Greg...the exhaust freak -2 '79 Malibus, one mostly stock one uh, not |
