Go Back   Automotive Forums .com Car Chat > Opel/Vauxhall > General Discussion
Old 06-12-2007, 12:31 AM   #1
12000
ignition barrel in a vp
what exactly do you have to do to remove and install a ignition barrel in a vp holden because i bought a new barrel from repco and want to use the old switch or put another switch on this barrel do i have to break the bolts and replace the housing for the barrel or can i just release the lock with a 3mm paper clip
12000 is offline   Reply With Quote
Old 06-14-2007, 11:26 PM   #2
mmcleo11
mmcleo11's Avatar
Re: ignition barrel in a vp
Remove the whole assembly and a locksmith can swap over everything and cut the new key barell to suit your old key as well so the same key works on door locks/ign barrell. No more than $80 for it to be swapped over and barell recut.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
mmcleo11 is offline   Reply With Quote
