Old 10-25-2007, 04:32 PM   #1
gphelmick
02 Cavalier headlight assembly
After removing the 2 bolts indicated in the Haynes Manual the headlight assembly stiil won't slide out. What else could be holding it in? Need to change the marker/turn signal bulb.
gphelmick is offline   Reply With Quote
Old 10-30-2007, 06:45 PM   #2
Gregrcool20
Re: 02 Cavalier headlight assembly
It says how to do so in the owners manuel is you still have it. If not,
If you look ontop of your headlight assembly, where your headlight and park like meet, there is a clip. look around with a flashlight and you will see it. There should be a cut out ontop, look in there then use a screwdriver to push on it then push down towards yourself. After the park light is out, the headlight will come out easily.
Gregrcool20 is offline   Reply With Quote
