Go Back   Automotive Forums .com Car Chat > Cadillac > Eldorado
Old 09-26-2007, 01:13 AM   #1
JohnFox22
Question H-E-L-P! 1996 Eldorado Code
Any help would be appreciated, thanks.
I have a 96 eldorado, the Service engine soon light is on along with the Traction control light and the Brake light. I am also getting the the "Service emissions system" message, along with "Service ignition system" message. Also the "theft system problem" message. Yeah thats right the thing is falling apart. The car will sometime idol at 1200 to 2000rpms, if I turn off the car and restart it a few times it will return to normal idol. Its idols loud too (all the time). Any Ideas? Also whats the difference between "History and Current", is it as simple at it sounds?? Current means its a current problem??Heres the codes...
PC0122 History
PC1122 History
PC1350 History
PC1375 History
PC1406 History
PC1579 History
IP1552 History
IP1910 History
IP2711 Current
No ACM
No SDM
TC0033 Current
TC0083 Current
No RSS
No PZM
No IRC
No RFA
No CCP
PCM?
Thanks again in advance.
JohnFox22 is offline   Reply With Quote
Old 09-26-2007, 09:05 AM   #2
DFBonnett
Re: H-E-L-P! 1996 Eldorado Code
Often a lot of unrelated codes are due to the computer receiving low voltage and thus producing bogus codes. Check and clean the battery connections and grounds. Inspect the cables themselves for swelled areas which would indicate internal corrosion. Check the battery voltage across the terminals as well as charging voltage.
DFBonnett is offline   Reply With Quote
