Speedometer
A friend who is familar with Isuzu's replace all the belts on my daughters 95 Rodeo. The speedometer hasn't worked since. I bought the repair manual for for 91 to 97 Rodeo's but not too much info there. Removed the speed sensor from the transmission, put it in a vise and metered it while running it with an electric drill. No readings but I don't know if that is a good test. Don't know where the other end of the harness is that comes off the sensor. Think I located the right fuse and it is okay. Wondering if there is a plug in the harness near the belts.
Another problem is a squeal from a belt when first starting the engine but on a second try the noise is gone. Sprayed belt dressing on all the belts a couple of times but always comes back after a few starts. Can't determine which belt. That's my problems folks and would sure appreciate any help. Thank you all. Jack |
![]() Join Date: Jul 2007
Re: Speedometer
Could be any one of the three, but I'd guess alternator belt first. There are 3 belts and 3 different ways to tension them. The alt belt requires loosening a bolt, then turning the tensioner bolt, then retightening the first bolt. I've heard belt dressing breaks down the rubber, shortening the life of your new belts. I'd get the squealer tensioned properly.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K '96 Jetta 249K '97 TJ 156K '02 VW Cabrio 70K '03 E46 107K |
#3 | ||||
![]() Join Date: Jul 2005
Re: Speedometer
//bc
1992 trooper 3.2L v6 sohc automatic...as is i love a good intermittent electrical challenge. . .especially when it's someone else's. |
Re: Speedometer
Yep, alternator belt needs to be pretty tight. That belt dressing crap isn't good for anything.
Re: Speedometer
the speedo might need a speed sensor gear inside the tranny , bolts in behind the speed sensor with one 10mm bolt.
