Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 01-05-2008, 11:16 PM
fly066 fly066 is offline
abs light
abs light came on in my 2001 chevy blazer comes on and sometimes it goes off for a short time but then reappears. anyone got any hints/help? thanks
Old 01-06-2008, 09:29 AM
old_master's Avatar
old_master old_master is offline
Advisor/Moderator
Re: abs light
A body capable scan tool is required to retrieve ABS DTC's. They will tell what circuits to check. They will NOT tell you what part is faulty.
Old 01-09-2008, 04:30 PM
drivena98 drivena98 is offline
Re: abs light
my 98 did the same thing for a while. i found a broken sensor wire behind the left front tire. your issue may be behind either tire.
Old 01-09-2008, 08:21 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: abs light
I had a broken speed sensor wire on the passenger side front hub of my '97 that I replaced but I still had to reset the Diagnostic Trouble Code after the repair.
Here's a pic,
Old 01-12-2008, 10:02 AM
hamlinhazel hamlinhazel is offline
Re: abs light
I have the same problem on my 2000 Chevy Blazer. How do you replace the wire? Do you have to take the brake and drum off to get to where the switch wire plugs in? Also, how do you reset the ABS light? Thanks for your help.
Old 01-12-2008, 12:42 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: abs light
A lot of the wiring is made into wheel bearing.
If you can repair the broken wire and get it where it will flex up and down with the wheel.
ABS brake codes will clear on there own when problem is fixed.
For more help or a new problem always start a New thread.
Saves highjacking other peoples problems and post.
MT
MT
Old 01-12-2008, 03:26 PM
Re: abs light
hamlinhazel,
not sure if 98s and 00s are the same but on mine you have to remove the rotor to get to 2 small allen screws behind the hub. then there are 2 brackets that hold the wire to the upper a-arm then it unplugs from the main wire that goes to the abs box. the whole wire you will replace is about 24 inches long and sort of expensive, about $75-80.00. i just spliced mine back together and no lights or problems since. good luck.
