Old 09-01-2007, 05:41 PM
KEFLON KEFLON is offline
Lifespan of Isopropyl alcohol? (used for paint stripping)
Hi guys
quick question like the title says:
How long does Isopropyl alcohol 99.9% last i.e. How many times can I reuse the same liquied?
Thanks
Old 09-01-2007, 05:47 PM
stevenoble's Avatar
Re: Lifespan of Isopropyl alcohol?
I've had my 'vat' of the stuff for about 8 months maybe longer and it is quite dirty now.But I filtered the paint dregs from it using an old piece of nylon stocking,so I am just left with the liquid now instead of all the 'slurry' that collects at the bottom.It still works fine although a fair bit of it has evaporated.Once it evaporates away I will buy a new bottle.
Steve Noble
Old 09-01-2007, 06:38 PM
Thats great thks, would u recommend that I filter the liquid after every use.
Thks
Old 09-01-2007, 06:43 PM
stevenoble's Avatar
Thks
Might be worth doing.It would certainly keep the sludgy buildup that accumulates at the bottom of the container to a minimum,although I don't think this buildup stops the Isopropyl from doing it's job.
Steve Noble
Old 09-01-2007, 08:41 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
99.9% essentially has no water content. That means that if any volume evaporates, the proportions of what remains stays unchanged. I have a vat that's nearly three years old. I've replaced some volume (due to evaporation), but it's still just as potent as it originally was.
PHOTOBUCKET SUCKS
Old 09-01-2007, 09:38 PM
jmwallac's Avatar
jmwallac jmwallac is offline
I've had the same stuff for almost a year and have stripped about 10 bodies and countless other parts. I'm better at stripping than anything else: just ask my wife!
I keep it in the bottle it came in; just pour it back after each use. If you let it sit, the junk sits at the bottom and the "good" stuff separates. I've tried filtering through a coffee filter, but didn't have much success. I don't think it needs to be filtered, although my stipped bodies tend to be tinted whatever color the last body was.
Recently completed projects:
Old 09-01-2007, 10:12 PM
MPWR's Avatar
Yeah, you can certainly filter the crap out, but it really effects the performance fot he alcohol little if at all. After stripping I scrub everything with soap and water, so I'm not really given to be concerned if the alcohol itself isn't quite clean.
PHOTOBUCKET SUCKS
