Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 08-22-2007, 03:33 PM   #1
sheadogsavannah
Unhappy 2000 Bravada leaking antifreeze
Today while driving I smelled antifreeze, so I checked for leaks as soon as I got home. I can't see where the actual leak is at; however, using a flashlight it appears to be at the bottom of the radiator. What is located at the bottom of the radiator that might be leaking? It has leaked on the oil filter and is dripping out from that area. There is a long metal guard that runs under the radiator and that has leaked antifreeze at both ends (I can't see the middle). My coolant overflow is dry and I can't get the radiator cap off. Any ideas on what my first step toward diagnosing this problem should be?
sheadogsavannah is offline   Reply With Quote
Old 08-22-2007, 11:41 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: 2000 Bravada leaking antifreeze
Check your radiator hoses. Search the area just under where the top radiator hose connects to the radiator.
Chris Stewart is offline   Reply With Quote
