Old 07-16-2007, 05:25 PM
import.only import.only is offline
system too lean fault...
I just dropped a new engine in my 96 3500. It was a remanufactured 350 vortec. I got a check engine light right off the bat due to incorrect timing. Fixed that, but now I get a check engine light that is on some times and off at others. The fault code is "System too lean (bank 2)". Can some one point me in the right direction with this problem. Thanks.
Light'em up
Old 07-16-2007, 08:58 PM
taillight taillight is offline
Re: system too lean fault...
Look for an air leak. Vacuum hose, Intake manifold gasket EGR or anything on that side.
Old 07-23-2007, 09:55 PM
Angry Re: system too lean fault...
ok I decided to change the o2 sensor on the right side because it called out bank 2, but I had no luck. I also looked for an intake leak. The light comes and goes. I want to check for a vacuum leak next. What would be the best way to do that? I heard you could let out some propane or butane around the intake to see if it starts idling rough. Is that right? Any other ideas?
Light'em up
Old 07-23-2007, 10:40 PM
777stickman 777stickman is offline
Propane I haven't tried. I use carb or brake cleaner. Need to just spray around intake, TBI, hoses, etc. If there's a leak you'll hear the RPM's change.
Just thought of something else. Do you have any kind of exhaust leak. An exhaust leak can actually suck air into the the exhaust system causing a lean O2 sensor reading.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 07-26-2007, 06:46 PM
I don't think I have an exhaust leak but then again haven't really checked. Just pulled the spark plugs and the ones on right seem to have more carbon build up then the ones on the left. I'm thinking that it it might be the injectors. When the engine was out I started clean the intake and when I went to pull the injectors out, two of them had pieces of the plastic clip fell off. I re-used them thinking they would be ok . I'm thinking that one or both of them is sitting loose in there and not spraying right. I'm going to take the intake apart today.
Light'em up
