| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Hopefuly someone here has already worked through all the finer aspects of piecing together a frankenstien project like mine.
I'm putting a 4G64 2.4 L stroker in a 95 AWD Talon using a built up block from a 91 Sonata, and a 1st Gen head. Question #1 Will a 90-91 turbo Talon oil pan work for this aplication? Question #2 Is the black top 93-94 Cam Angle Sensor the one to use? (that's the magnetic one not the optical right?) Question #3 I also need the water pipe and thermostat housing. Will all the years between 90-94 be the same? Question #4 Are any of these parts the same on a non turbo model and are there any differences between the Eclipse, Talon, and Laser even in build quality? These are the last items that I need to finally get my baby going again, thanks for any input.
95 Talon Tsi AWD 5spd 2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Re: Expertise greatly needed - 2.4 stroker
1, yes, only turbopan with oil retun hole
2, Blacktops are optical and just have better resilution, any 1g cas will work, Non & Turbo models 3, 90-92 turbo T-stat, non turbo dosen't have the extra coolant nipple. 91-92 turbo waterpipe if you're using a water/oil cooled turbo, 90 turbo waterpipe if only oil cooled turbo. I know there are a couple dedicated forums and websites to this swap, even a very long thread on tuners...
DSM geek |
Right on......Thanks so much for the detailed information. I don't surf the net too often, are you refering to DSMtuners.com, or is there a thread on Automotiveforums that I should refer to?
When you say 2.4 stroker, is it going to be an actual 2.4L, or a regular 2.3L like most other stroker guys run.
Here's a nice little write-up about an actual 2.4L |
G4CP engines are true 2.4l.
DSM geek |
Yes it is an actual 2.4L
I am not really that familiar with looking up threads, I have tried searching in automotive forums but haven't yet found the write ups on the 2.4L Is there something in particular you would recommend reading ? What kind of vehicle does a G4CP engine come out of ?
Oh shit, sorry about that, I forgot to post the link....my bad.
http://www.pinktemple.com/stroker.html |
Thanks for the article. I'm using the Sonata block, so I shouldn't have some of those clearance issues. But I probably will have to hammer out the oil pan. You saved me from having to find out the hard way!
THANK YOU.
Just need to clear something up if anyone can help. Is the black top Cam Angle Sensor off of any 93 - 94 Talon, Eclipse or Laser except the 1.8L Laser ? -thanks
